When you want something a bit more discreet, this low-key, classic look is perfect.
Griffin's All Clear Identity cases get both their good looks and their protective abilities from a skillful layering of materials that deflect impacts and vibration while letting the beauty of your iPhone show through.
Identity cases protect your phone from four-foot drops. The dual-material frame is made from color-keyed shock-absorbent rubber bonded to a hard polycarbonate plastic frame. Swap any Identity frame and back plate to create your own unique look, thanks to Identity's interchangeable design.
- Griffin Identity All Clear - back cover for mobile phone
- Product Type
- Back cover for mobile phone
- Material
- Polycarbonate, rubber
- Clear
- Material
- Clear
Carrying Case
- Protective cover
- Recommended Use
- For mobile phone
- Protection
- Scratch-resistant, impact protection, drop-proof
- Cover Type
- Back cover
- Camera lens cutout, hard shell, transparent backside, raised edges, dual layer
