Griffin Car Windscreen/Dashboard Mount for iPhone & Smartphone
Quicklinx: C7TRWS00 Mfr#: GC42555
WindowSeat mounts your smartphone handsfree at eye level on your car's windshield or dashboard, putting your maps, apps and more safely in view and within reach.
Sized to hold any smartphone up to 92 mm wide (3.6 in.), the self-adjusting, spring-loaded cradle makes it easy to snap your phone into the cradle one-handed. WindowSeat is compatible with most cases, too, so you don't have to remove your phone from its case. WindowSeat's heavy-duty suction cup uses a locking lever to grip onto your windshield. A ball joint adjusts the cradle a full 360 degrees to the perfect angle, then locks it in place. And a built-in cable clip holds power and AUX cables for quick, easy connections.
For localities that prohibit windshield mounts, we've included an adhesive mounting plate for secure mounting on your dashboard or console.
Griffin WindowSeat Universal Auto Mount - car holder
Car holder
Intended For
Mobile phone
Suitable For Installation
Car
Car holder
Intended For
Mobile phone
Car
Rotation
360°
Placing / Mounting
Wind shield
