Product
Brand
Griffin AirStrap 360 for iPad Air - Black
Clearance!
Clearance
Quicklinx: 9YRQWS00 Mfr#: GB39053-2
A molded frame with thick, comfortable, contoured grips surrounds your iPad, protecting the edges without getting in the way of your controls or ports. Slip your hand under the wide neoprene strap on the back. AirStrap hugs your hand, making your iPad easier to hold whether you're reading in a coffee shop or checking out the headlines as you ride the 6:45 in to work.
Griffin AirStrap - back cover for tablet
Back cover for tablet
Apple iPad Air
Carrying Case
Protective cover
Recommended Use
For tablet
Cover Type
Back cover
Carrying Strap
Hand strap
Camera lens cutout, protective frame, port cut-outs, rotating hand strap
Apple iPad Air
