Griffin AirStrap 360 for iPad (5th Gen) Black
Quicklinx: D409WS00 Mfr#: GB43578
Type: Case
Hurry, only 3 left in stock!
£23.39 ex VAT
£28.06 inc VAT
A molded frame with thick, comfortable, contoured grips surrounds your iPad, protecting the edges without getting in the way of your controls or ports. Slip your hand under the wide neoprene strap on the back. AirStrap hugs your hand, making your iPad easier to hold whether you're reading in a coffee shop or checking out the headlines as you ride the 6:45 in to work.
Griffin AirStrap 360 - back cover for tablet
Back cover for tablet
Screen Size Compatibility
9.7"
Material
Neoprene, polycarbonate, thermoplastic polyurethane (TPU)
1-year warranty
Apple 9.7-inch iPad (5th generation); 9.7-inch iPad Pro
Material
Carrying Case
Protective cover
Recommended Use
For tablet
9.7"
Protection
Scratch-resistant, drop-proof
Cover Type
Back cover
Carrying Strap
Hand strap
Max Height of Shock Resistance
0.8 m
1 year
Apple 9.7-inch iPad (5th generation) , Apple 9.7-inch iPad Pro
Type: Case
Brand: Griffin
Price Range Ex VAT: 0 - 50
