Griffin Airsrtap 360 iPad Air 2, iPad Pro 9.7"
Quicklinx: C3X4WS00 Mfr#: GB41878
A molded frame with thick, comfortable, contoured grips surrounds your iPad, protecting the edges without getting in the way of your controls or ports. Slip your hand under the wide neoprene strap on the back. AirStrap hugs your hand, making your iPad easier to hold whether you're reading in a coffee shop or checking out the headlines as you ride the 6:45 in to work.
Griffin AirStrap 360 - back cover for tablet
Back cover for tablet
Screen Size Compatibility
9.7"
Material
Neoprene, polycarbonate, thermoplastic polyurethane (TPU)
1-year warranty
Material
Carrying Case
Protective cover
Recommended Use
For tablet
9.7"
Protection
Scratch-resistant, drop-proof
Cover Type
Back cover
Carrying Strap
Hand strap
1 year
