Get a solid grip on your GoPro and keep it afloat better than ever before with The Handler. This floating hand grip gives you stability and control to get your shot, and the quick-release base lets you switch between mounts with ease. Drop it in the water and the bright orange end of the handle pops to the surface, making it easy to spot.
- Keeps your GoPro afloat better than ever before so you can shoot in and around the water worry-free
- Easy to switch between mounts with a quick-release base
- Makes it easy to aim your camera and capture all kinds of different angles
- Comfortable, non-slip construction for a secure grip
- Perfect for surfing, kayaking, wakeboarding and other water sports
- Bright orange cap piece is easy to spot if you ever drop it in the water
- Enables more stable footage than holding the camera by hand
- Wrist strap lanyard included for extra security
What's Included
- Floating Hand Grip
- Wrist Strap
Compatibility
- All GoPro cameras
- GoPro The Handler support system - shooting grip
- Product Type
- Support system - shooting grip
- Designed For
- HERO+; HERO3; HERO3+; HERO4; HERO5; HERO6 Black; HERO7 Black, Silver, White
- Product Type
- Support system
Tripod
- Supported Devices
- Action camera
- Support Type
- Shooting grip
- Floating
- Included Accessories
- Wrist strap, thumb screw wrench
- Designed For
- GoPro HERO+ , GoPro HERO3 , GoPro HERO3+ , GoPro HERO4 , GoPro HERO5 , GoPro HERO6 Black , GoPro HERO7 Black, Silver, White
