Product
GoPro Handlebar / Seatpost / Pole Mount
Quicklinx: D48PWS00 Mfr#: AGTSM-001
Mount your GoPro to handlebars, seatposts, ski poles and more. The hinged, non-slip design easily clamps to different mounting locations or secures to a pole or pipe to create a handheld boom. The mounting buckle lets you move your GoPro between mounts on the move, and the base features 360° rotation to help achieve the perfect angle for every shot. Fits 9 to 35 mm (0.35 to 1.4 in) diameter tubes.
  • Hinged, non-slip design sets up in seconds and clamps to any 0.35 to 1.4 in (9 to 35 mm) diameter tube
  • Rotating base features 360° rotation with 16 secure positions, ensuring the perfect angle and allowing rapid changes in perspective for more dynamic footage
  • The mounting buckle lets users move their camera between mounts on the move, enabling fast and easy changes in perspective
  • Durable construction prevents slipping and breaking and minimises vibration and camera shake
  • No loose parts to drop or lose
What’s Included
  • Handlebar/Seatpost/Pole Mount
  • Large Rubber Insert
  • Small Rubber Insert
  • Vertical Mounting Buckle
  • Long Thumb Screw
Compatibility
  • All GoPro cameras
GoPro HANDLEBAR / SEATPOST / POLE MOUNT - support system - handle bar mount
Support system - handle bar mount
Placing / Mounting
Handlebar, pole mount, seat post mount
HD HERO2; HERO; HERO+; HERO3; HERO3+; HERO4; HERO6 Black; HERO7 Black, Silver, White
Support system
Tripod
Placing / Mounting
Supported Devices
Action camera
Support Type
Handle bar mount
Kit Content
Kit Content
(1) x handlebar mount , (1) x large rubber insert , (1) x small rubber insert , (1) x vertical surface buckle , (1) x thumb screw
GoPro HD HERO2 , GoPro HERO , GoPro HERO+ , GoPro HERO3 , GoPro HERO3+ , GoPro HERO4 , GoPro HERO6 Black , GoPro HERO7 Black, Silver, White
