El Grande is an aluminium extension pole that takes your GoPro to new heights – literally. Its extra extension (up to 97 cm) allows you to capture new perspectives and gets you closer to the action. Plus, it’s collapsible down to 38 cm and is compact enough for any on-the-go adventure.
- Extends to 97 cm for new perspectives and to get you closer to the action. Collapses to 38 cm, so it’s easily packable for on-the-go use
- Includes an integrated ball-and-socket design at the end of the pole, allowing you to make adjustments or swivel your GoPro 360° without having to stop and unmount your camera
- Premium oversized grip allows you to comfortably use two hands to hold El Grande for a better overall experience
- Twist-lock design for quick and easy use
- Durable and waterproof
What’s Included
- Extension Pole
- Swivel Base with Thumb Screw
- Wrist Lanyard
Compatibility
- All GoPro cameras
- GoPro EL GRANDE support system - shooting pole
- Product Type
- Support system - shooting pole
- Head Type
- Ball and socket
- Tripod Operating Height
- 97 cm
- Limited lifetime warranty
- Designed For
- HD HERO; HD HERO2; HERO Session; HERO+; HERO+ LCD; HERO3; HERO3+; HERO4; HERO4 Session; HERO5; HERO5 Session; HERO6 Black; HERO7 Black, Silver, White
- Product Type
- Support system
- Folded Length
- 38 cm
Tripod
- Tripod Legs Lock Type
- Twist to lock
- Quick Release System
- Max Operating Height
- 97 cm
- Support Type
- Shooting pole
Head
- Head Type
- Ball and socket
- Pan (degrees)
- 360
- Included Accessories
- Wrist strap
- Limited warranty - limited lifetime warranty
- Designed For
- GoPro HD HERO , GoPro HD HERO2 , GoPro HERO Session , GoPro HERO+ , GoPro HERO+ LCD , GoPro HERO3 , GoPro HERO3+ , GoPro HERO4 , GoPro HERO4 Session , GoPro HERO5 , GoPro HERO5 Session , GoPro HERO6 Black , GoPro HERO7 Black, Silver, White
