Your basket is empty
GoPro Dual Battery Charger + Battery
Quicklinx: BFLSWS00 Mfr#: AHBBP-401
Conveniently charge your camera batteries with the dual battery charger, the GoPro charger that allows you to charge two batteries simultaneously. Featuring USB compatibility, you can power it with most standard USB power adapters, the GoPro auto or wall charger, or a computer. Dual LED indicator lights display the charging status, so you know when your batteries are ready for action.
GoPro Dual - battery charger + AC power adapter + battery Li-Ion
Battery charger
Lithium Ion 1160 mAh
Cables
USB power cable
HERO4
Battery charger + AC power adapter battery
Input Connectors
4 pin USB Type A
Input Connectors Qty
1
AC Power Adapter Included
LED indicator
Lithium Ion
1160 mAh
Supported Battery
Max Supported Qty
2
Lithium Ion
USB power cable
GoPro HERO4
