This ultra versatile mount can be used three main ways: as a camera grip, extension arm or tripod. The folding arm is perfect for POV or follow-cam footage, and makes it easy to capture selfies without the mount appearing in the shot. When detached from the arm, the handle doubles as a camera grip. Stored inside the handle is a lightweight, mini tripod that can be removed and used on its own or combined with the handle. Expands to 50.8 cm, collapses to 19 cm.
- Can be used three main ways: as a camera grip, extension arm or tripod
- Configurable for a wide range of uses, from capturing POV footage and selfies, to follow-cam, static tripod shots and more
- Folding arm makes it easy to capture selfies without the mount appearing in the shot
- Use the arm and grip as a handheld boom for immersive POV or follow-cam footage
- Handle can be detached from the arm and used as a camera grip
- Removable tripod conveniently stores inside the handle
- Lightweight, mini tripod can be used on its own or combined with the handle
- Waterproof construction for use in and out of the water
- Measures 50.8 cm when fully extended, collapses to 19 cm
What's Included
- Extension Arm
- Grip
- Tripod
- Thumb Screw
Compatibility
- All GoPro cameras
- GoPro 3-way shooting grip / mini tripod /shooting grip / mini tripod / selfie stick
- Product Type
- Shooting grip / mini tripod /shooting grip / mini tripod / selfie stick
- Designed For
- HD HERO; HD HERO2; HERO Session; HERO+ LCD; HERO3; HERO3+; HERO4; HERO4 Session; HERO5; HERO5 Session; HERO6; HERO7 Black, Silver, White
- Product Type
- Designed For
- GoPro HD HERO , GoPro HD HERO2 , GoPro HERO Session , GoPro HERO+ LCD , GoPro HERO3 , GoPro HERO3+ , GoPro HERO4 , GoPro HERO4 Session , GoPro HERO5 , GoPro HERO5 Session , GoPro HERO6 , GoPro HERO7 Black, Silver, White
