Google Pixelbook Go Core i5 8GB 128GB - Just Black
Quicklinx: FSTKWS00 Mfr#: GA00521-UK
  • Core i5
  • IEEE 802.11n
Good to go.
Lets you stay unplugged for up to 12 hours, so you don’t need to carry a charger. And when you do need a charge, get up to 2 hours of use in just 20 minutes so you can keep going.
Made to Move.
Pixelbook Go is lightweight. It’s 13 mm thin with a grippable design, making it easier to carry.
Get it done. Fast.
It starts up in seconds, and makes working a breeze. The 8th Gen Intel Core processor is built for speed and responsiveness, powering everything you do.
Go Without Worry.
Pixelbook Go is designed to prevent things from getting off track. The Titan C security chip and built-in anti-virus software help protect your data. And Chrome OS updates automatically, always giving you the latest features and security.
Built for Comfort.
A backlit keyboard and Hush Keys make using Pixelbook Go comfortable and quiet. The touchpad is spacious and accurate, so you only need to use a light touch. The fanless design stays cool to let you comfortably use it on your lap.
Ready to Entertain.
With a full high-definition touch screen display and dual stereo speakers, you get amazing picture and sound for watching movies, editing photos, or video chatting.
High-Resolution Duo Cam.
1080p webcam makes video chatting feel like you’re there.
The Fast Way to Get Things Done.
The Google Assistant is available with the touch of a key or by saying "Hey Google".
Your Favourite Apps on Pixelbook Go.
Explore apps for work, play and everything else.
Built-in Virus Protection.
Go worry-free, knowing that you are protected from viruses.
Keep your Data Protected.
The Titan™ C security chip ensures that your information, passwords and operating system are protected on your Pixelbook Go.
Always up to Date.
Chrome OS automatically updates, so you always have the latest security
  • Grippable design
    Textured bottom makes it easier to carry.
  • Charge in minutes
    Get up to 2 hours of battery use in just 20 minutes of charge.
  • Starts fast
    Starts up in seconds so it's ready when you are.
  • Goes fast
    The Intel Core processor is quick and responsive.
  • Brilliant 13.3" touchscreen display
    High definition picture with up to 4K display.
  • High-resolution Duo Cam
    1080p webcam makes video chatting feel like you're there.
  • Dual, front-firing speakers
    Whether you're watching your favourite movie or listening to your favourite song, enjoy stereo-quality sound.
  • Quiet and comfortable
    Minimise noise disruption with Hush Keys. And with the backlit keyboard, you can do more from anywhere, even in the dark.
  • Keep your data protected
    The Titan C security chip ensures your information, passwords, and operating system are protected on your Pixelbook Go.
Google Pixelbook Go - 13.3" - Core i5 - 8 GB RAM - 128 GB SSD
Chromebook
Operating System
Chrome OS
Intel Core i5
8 GB
Storage
128 GB SSD
Display
13.3" touchscreen 1920 x 1080 / Full HD
Graphics
Intel HD Graphics
Keyboard Backlight
Integrated Webcam
802.11a/b/g/n/ac, Bluetooth 4.2
Up to 12 hours
Ambient light sensor, magnetometer
Security
Titan-C Security Chip
Just black
31.1 cm x 20.63 cm x 1.34 cm
1.061 kg
Region: United Kingdom
Chromebook
Operating System
Google Chrome OS
Processor / Chipset
CPU
Intel Core i5
RAM
8 GB
Storage
Main Storage
128 GB SSD
Display
13.3"
Touchscreen
Resolution
1920 x 1080 (Full HD)
Widescreen
Colour Gamut
72% NTSC
72% NTSC colour gamut
Audio & Video
Graphics Processor
Intel HD Graphics
Camera
Yes - 1080p
Resolution
2 Megapixel
Frame Rate
60 frames per second
Sound
Stereo speakers, two microphones
Input
Keyboard, touchpad
Keyboard Backlight
Communications
Wireless
47 Wh
Run Time
Up to 12 hours
AC Adapter
Output
45 Watt, 5 / 9 / 15 / 20 V
Connections & Expansion
USB-C , Headphone output
Just black
Case Material
Magnesium alloy
Integrated Options
Security
Power adapter
USB-C charge cable
FIDO Certified
Localization
1.061 kg
