Google Pixel 3a XL 64GB - Just Black
Quicklinx: FMFLWS00 Mfr#: GA00760-UK
  • Android
Pixel's extraordinary camera, Google Assistant built in and a battery that lasts all day - everything is possible with Google Pixel 3a XL.
The camera that does the work for you.
Night Sight
Lose the flash, get the shot. Night Sight gives you rich detail and colour, even in the dark.
Depth editor
Focus on what matters by adjusting the depth of field.
Colour pop
Make the colour pop, while softening the background in black and white.
Unlimited Storage
Save your photos and videos with free, unlimited storage in high quality with Google Photos.
The power to do more
All-day battery.
Lasts up to 30 hours. Pixel’s Adaptive Battery learns your favourite apps and reduces power to those you rarely use.
Fast charging.
Enjoy up to 7 hours of use on a 15-minute charge with the 18 W adaptor included.
Google Assistant
Make Google do it.
Your Google Assistant can send texts, find answers, get commute times, set reminders and more.
The easiest way to get things done.
Do more with your Google Assistant. Just ask, or give your pixel a squeeze.
Peace of mind built in.
Secured with Titan M.
From passwords to the OS, Google’s custom-made Titan M security chip helps protect your most sensitive data.
3 years of updates.
Automatic security and OS updates will make sure that your phone is protected against the latest threats.
Specs
Operating system:
The latest Android 9.0 Pie. Minimum 3 years of OS updates.
Display:
Full-screen 6.0" display/152.4 mm display
FHD+ (2160 x 1080) OLED at 402 ppi
18:9
Always-on display
Now Playing
100,000:1 super contrast ratio
True black level
Full 24-bit depth or 16 million colours
D67 white point
Cameras:
Rear camera - 12.2 MP dual-pixel; 1.4 µm pixel width; Auto-focus with dual-pixel phase detection; Optical + electronic image stabilisation; ƒ/1.8 aperture; 76° field of view
Rear Camera Video - 1080p @ 30fps, 60fps, 120fps; 720p @ 30fps, 60fps, 240fps; 4K @ 30fps
Front camera - 8 MP; 1.12 µm pixel width; ƒ/2.0 aperture; Fixed focus; 84° field of view
Front Camera Video - 1080p @ 30fps; 720p @ 30fps; 480p @ 30fps
Processors:
Qualcomm® Snapdragon™ 670
2.0 GHz + 1.7 GHz, 64-bit Octa-Core
Adreno 615
Titan M security module
Memory and storage:
4 GB LPDDR4x RAM
64 GB storage
Battery:
3700 mAh battery
USB-C™ 18 W adaptor with USB-PD 2.0
18 W fast charging
Ports:
USB-C™ USB 2.0
Single nano SIM
3.5 mm audio jack
What's in the box:
Pixel 3a XL
18 W USB-C™ power adaptor
1 m USB-C to USB-C cable (USB 2.0)
Quick Start Guide
Quick Switch Adaptor
SIM tool
Mobile Phones from BT Shop
All of the mobile phones we sell here on BT Shop are unlocked and sim-free, meaning they can be used on any network. You do not need to be a BT Mobile customer to use a phone purchased from BT Shop.
If you are looking for a great SIM Only deal, or you need a new handset with a data plan, then you need to head over to bt.com now. We can connect you to fast 4G in more places than O2, Vodafone and Three, and you’ll get free, unlimited internet access at 5 million BT Wi-fi hotspots.
BT Mobile
  • Night Sight
    Lose the flash, get the shot. Night Sight gives you rich detail and color, even in the dark.
  • Depth editor
  • Color pop
    Make the color pop while softening the background in black and white.
  • Long-lasting battery
    The battery lasts up to 30 hours. Pixel's Adaptive Battery learns your favorite apps and reduces power to the ones you rarely use.
  • Fast charging
    Enjoy up to 7 hours of use on 15-minute charge.
  • Make Google do it
    Your Google Assistant can send texts, answers, and more.
  • Know who is calling, and why
    Get help with just a tap. Screen unknown calls, find out why they are calling, and see a real-time transcript of their response.
  • Secured with Titan M
    From passwords to OS, Google's custom made Titan M security chip helps protect your sensitive data.
Google Pixel 3a XL - just black - 4G smartphone - 64 GB - CDMA / GSM
4G smartphone
Display
OLED display - 2160 x 1080 pixels - 6" - 402 ppi - 18:9
Qualcomm Snapdragon 670 2 GHz (8-core) - 64-bit
Graphics Accelerator
Qualcomm ADRENO 615
RAM 4 GB / 64 GB
Operating System
Android 9.0 Pie
Main Camera
12.2 Megapixel - f/1.8 - focus: automatic
Front Camera
8 Megapixel f/2.0 - focus free
Service Provider
Not specified
SIM Card
Single-SIM - nano SIM, Electronic SIM card (e-SIM)
Wireless Interface
NFC, Wi-Fi 5, Bluetooth
Security Devices
Fingerprint reader
Messaging Services
SMS, MMS
Connectors
3.5 mm headset jack, USB-C
Just black
76.1 mm x 8.2 mm x 160.1 mm
167 g
Smartphone
Touch
76.1 mm
8.2 mm
160.1 mm
167 g
Body Colour
Just black
Body Material
Polycarbonate
Cellular
CDMA2000 1X / GSM / WCDMA (UMTS)
Mobile Broadband Generation
4G
Service Provider
Not specified
Operating System
Android 9.0 Pie
Intelligent Assistant
Google Assistant
Navigation
GPS, GLONASS, Galileo
SIM Card Type
Nano SIM, Electronic SIM card (e-SIM)
SIM Card Qty
Single-SIM
Input Device
Multi-touch
Messaging & Internet
Messaging Services
SMS, MMS
Communications
Data Transmission
GPRS, EDGE, EV-DO, HSDPA, HSUPA, HSPA+, FDD-LTE, TDD-LTE
2G Band
850 GSM, 900 GSM, 1800 GSM, 1900 GSM, 800 CDMA2000 1X, 1900 CDMA2000 1X
3G UMTS Band
Band 1, Band 2, Band 4, Band 5, Band 8
3G UMTS Frequency
2100, 1900, 1700, 850, 900
4G LTE Band
Band 1, Band 2, Band 3, Band 4, Band 5, Band 7, Band 8, Band 12, Band 13, Band 17, Band 20, Band 25, Band 26, Band 28, Band 32, Band 38, Band 40, Band 41, Band 66
4G LTE Frequency
FDD 2100, FDD 1900 PCS, FDD 1800+, FDD 1700 - 2110 AWS, FDD 850, FDD 2600, FDD 900, FDD 700a, FDD 700c, FDD 700b, FDD 800 DD, FDD 1900+, FDD 850+, FDD 700 APT, FDD 1500 L, TDD 2600, TDD 2300, TDD 2500, FDD 1700 - 2110 AWS-3
Wireless Interface
NFC, IEEE 802.11a/b/g/n/ac, Bluetooth 5.0 LE
Phone Features
Phone Functions
Speakerphone, voice control, call timer, conference call, flight mode, voice dialing, vibrating alert
Sensors
Accelerometer, ambient light sensor, proximity sensor, barometer, magnetometer, gyro sensor, haptics sensor, Active Edge
Security Devices
Fingerprint reader
Additional Features
Dual microphones, MIMO technology, Android Sensor Hub, Noise suppression, Night Shift, ARCore, Google Lens, Titan M Security Module, Pixel Imprint sensor
Media Player
Supported Digital Audio Standards
Apt-X, LDAC, apt-X HD
Clock Speed
2 GHz
Processor Core Qty
8-core
64-bit Architecture
Graphics System
Qualcomm ADRENO 615
RAM
LPDDR4X SDRAM - 4 GB
Internal Memory Capacity
64 GB
Front Camera
Sensor Resolution
8 Megapixel
Lens Aperture
F/2.0
Focus Adjustment
Focus free
Field of View (FoV)
84 degree(s)
Pixel Size
1.12 µm
Video Resolutions
1920 x 1080 (1080p) at 30 fps, 1280 x 720 (720p) at 30 fps, 640 x 480 (VGA) at 30 fps
Main Camera
Sensor Resolution
12.2 Megapixel
Optical Image Stabiliser
Optical Image Stabiliser (OIS)
Lens Aperture
F/1.8
Field of View (FoV)
76 degree(s)
Pixel Size
1.4 µm
Focus Adjustment
Automatic
Camera Modes
Portrait mode
Video Resolutions
1920 x 1080 (1080p) at 30 fps, 1920 x 1080 (1080p) at 60 fps, 1280 x 720 (720p) at 30 fps, 3840 x 2160 (4K) at 30 fps, 1280 x 720 (720p) at 60 fps, 1920 x 1080 (1080p) at 120 fps, 1280 x 720 (720p) at 240 fps
Electronic Image Stabiliser (EIS), dual pixel phase detection, Motion Auto Focus
Display
OLED display
Diagonal Size
6"
Display Resolution
2160 x 1080 pixels
Display Format
Full HD+
Pixel Density
402 ppi
Aspect Ratio
18:9
Colour Depth
16.7 million colours
Contrast Ratio
100000:1
Always-on display, Now Playing
Connector Type
USB Type-C - 24 pin USB-C , Headset jack - mini-phone 3.5mm
3700 mAh
SIM card removal tool, Quick switch adapter, 18W USB-C power adapter, USB-C to USB-C cable (1 m)
