Google Nest Wifi Point
Quicklinx: FGH1WS00 Mfr#: GA00667-GB
  • IEEE 802.11n
More than 50 in stock
£107.50 ex VAT
£129.00 inc VAT
Meet the new Nest Wifi.
Strong connection. Every direction.
Nest Wifi blankets your whole home in fast, reliable Wi-Fi and keeps buffering at bay in every room.
Nest Wifi
Nest Wifi is a scalable system that gives both whole-home coverage and a consistently strong signal. Each Nest Wifi point is also a smart speaker with the Google Assistant.
The point
Each point works with the router to expand coverage and help keep Wi-Fi fast in every room.
Plus it’s a smart speaker that you can play music on, find answers, and more.
Which Nest Wifi system is right for you?
Get coverage in every corner, no matter the size and shape of your home.
One router.
Up to 120 square metres
One router and one point.
Up to 210 square metres
One router and two points.
Up to 300 square meters
Set up and manage your Wi-Fi with the Google Home app.
Network controls.
Manage your network right on your smartphone.
Parental peace of mind.
Control online time for the kids and block explicit content.
Prioritise devices.
Pick which devices get faster speeds when you need it.
Share Wi-Fi with your friends.
Create a guest network and easily share your password.
Run a speed test.
You can always see how fast your Wi-Fi is running.
Hands-free help around the house.
The Nest Wifi point has a speaker with the Google Assistant, so you can play music, manage your Wi-Fi network, find answers, control your connected devices and more using your voice.
More points to expand.
Add more points if you need more coverage and help around the house.
Nest Wifi points require a Nest Wifi router or Google Wifi router.
In the box
1 Nest Wifi point
1 power adaptor
  • Stream with speed
    One Nest Wi-Fi router with one Wi-Fi point is strong enough to handle up to 200 connected devices, and fast enough to stream multiple 4K videos at a time.
  • Wi-Fi you'll want to show off
    Nest Wi-Fi was made with your home in mind.
  • Being part of your home means respecting your privacy
    When it comes to privacy, you know what's right for you and your family. Here's how to control your privacy on your Nest Wi-Fi point.
  • Hands-free help around the house
    The Nest Wi-Fi point has a speaker with the Google Assistant so you can play music, manage your Wi-Fi network, find answers, control your connected devices, and more, using your voice.
Google Nest Wifi - Add-on - Wi-Fi system - 802.11a/b/g/n/ac, Bluetooth 4.2 - desktop
Wi-Fi system - mesh
Enclosure Type
Desktop
Wi-Fi System Components
Extender
Wi-Fi System Coverage
Up to 1,600 sq.ft
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, Bluetooth 4.2
Frequency Band
2.4 GHz / 5 GHz
Connected devices: 100
Intelligent Assistant
Google Assistant
Roaming function, 2T2R MIMO technology, MU-MIMO technology, beamforming technology, band steering
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11k, IEEE 802.11ac, Bluetooth 4.2, IEEE 802.11v
Snow
10.22 cm x 10.22 cm x 8.72 cm
350 g
United Kingdom
Wi-Fi system - mesh
Extender
Up to 1,600 sq.ft
Enclosure Type
Desktop
Wireless
Frequency Band
2.4 GHz / 5 GHz
Encryption Algorithm
WPA3
Wi-Fi Rating
AC1200
Mesh Networking
1 x ARM 1.4 GHz
RAM
768 MB
Flash Memory
512 MB
Built-in Devices
Microphone, speaker, touch sensor
Internet of Things (IoT)
Communications Technology
Bluetooth Low Energy (LE)
Google Assistant
External power adapter - 15 Watt
Enclosure Colour
Snow
United Kingdom
10.22 cm
10.22 cm
8.72 cm
350 g
Type: Wi-Fi system
Connectivity: Wireless
Protocol: IEEE 802.11ac
Protocol: IEEE 802.11b
Protocol: IEEE 802.11g
Protocol: IEEE 802.11n
Protocol: Bluetooth 4.2
Brand: Google
Stock Status: In stock
