Google Nest Mini Chalk - Twin Pack
Quicklinx: FVLCWS00 Mfr#: GA00638-GB-TWIN
Nest Mini.
Better sound. Huge help.
Meet the new Nest Mini. Your music sounds bigger and better than ever. And the Google Assistant is a huge help around the house.
Engineered for sound. Designed for your home.
Bigger, richer sound.
Google Nest Mini has 2x stronger bass than the original Mini.
Made with the environment in mind.
Durable fabric top made from 100% recycled plastic bottles.
Improved voice recognition.
Ask for help from across the room.
Stream your music
Play music and entertainment from your favourite apps with your voice.
Just ask your Google Assistant. Or stream to Nest Mini from your phone.
Get help around your home with your Google Assistant.
Just ask and get the best of Google – weather, news or almost anything. Hear your personalised schedule, commute and reminders. Set timers and alarms.
Control your home with just your voice.
Dim the lights, turn on the TV or turn up the heat – just ask your Google Assistant. Works with hundreds of compatible smart devices.
  • Bigger, richer sound
    Google Nest Mini has 40% stronger bass than the original Mini.
  • Made with the environment in mind
  • Improved voice recognition
  • Easy volume controls
    LEDs light up to show your volume controls when you approach it.
  • Play music and entertainment from your favourite apps with your voice
  • Get help around your home with your Google Assistant
    Just ask and get the best of Google - weather, news, or almost anything. Hear your personalised schedule, commute, and reminders. Set timers and alarms.
Google Nest Mini - Gen 2 - smart speaker
Smart speaker
United Kingdom
Speaker Type
Active
Wi-Fi, Bluetooth
Intelligent Assistant
Google Assistant - direct
Streaming Services
Chromecast
Speaker Details
Speaker - mono - active
Chalk
Sound Effects
360° sound
4.2 cm
Dimensions - Diameter
9.8 cm
181 g
Smart speaker
Hands-Free Function
Microphone
3 microphones array
Enclosure Colour
Chalk
Enclosure Material
Plastic, fabric
United Kingdom
Speaker System
Speaker Type
Active
Amplifier
Integrated
Sound Effects
360° sound
IEEE 802.11b/g/n/ac, Bluetooth 5.0
Internet Streaming Services
Chromecast
Recommended Placing
Wall-mountable / table-top
Internet of Things (IoT)
Hub
Integrated
Google Assistant
Voice Control
Direct
Speaker System Details
Speaker Details
Driver Details
Full-range driver
Power adapter
Power Source
AC power adapter
Cord Length
1.5 m
Diameter
9.8 cm
4.2 cm
181 g
