Product
Go Lamp Generic GO Lamp For NEC VT470/670 Projectors
Quicklinx: 8PRGWS00 Mfr#: GL443
Type: Projector lamp
Stock Status: In Stock, Used Stock
3 in stock
£107.71 ex VAT
£129.25 inc VAT
Standard delivery Delivered within 3-5 working days
GO Lamps Projector lamp (equivalent to: NEC 50030763, VT75LPE) - NSH - 180 Watt - 2000 hour(s) - for NEC LT280, LT380, VT470, VT670, VT676; MultiSync VT470; ViewLight VT470, VT670 and VT676.
GO Lamps projector lamp
Projector lamp - NSH - 180 Watt
OEM Manufacturer Lamp Equivalent
Bulb life cycle
2000 hour(s)
2 years warranty
NEC LT280, LT280G, LT380, LT380G, VT470, VT470G, VT470GK, VT670, VT670G, VT676, VT676G; MultiSync LT280, LT380, VT470, VT470G, VT670; ViewLight VT470J, VT670J, VT676J
Projector lamp
Lamp
NSH
180 Watt
Life Cycle
2000 hour(s)
NEC LT280, LT280G, LT380, LT380G, VT470, VT470G, VT470GK, VT670, VT670G, VT676, VT676G , NEC MultiSync LT280, LT380, VT470, VT470G, VT670 , NEC ViewLight VT470J, VT670J, VT676J
Used stock
What is used stock?
Accessories Packaging Functional Software Manuals
Ref: 8PRG 033717
Condition: Customer return - item has been used and shows signs of use. New bulb required.
This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is not present or functional  This part of the stock item is present and in good condition  £15.38
Legend
  • This part of the stock item is present and in good conditionThis part of the stock item is present and in good condition
  • This part of the stock item is not present or functionalThis part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standardThis part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.This item has not been tested.
Brand: Go Lamp
Stock Status: Used Stock
Price Range Ex VAT: 100 - 150
