GO Lamp for ET-LAB80. Lamp module for PANASONIC PT-LB75. PT-LB80 projectors. Type = HS. Power = 220 Watts. Lamp Life (Hours) = 3000. Now with 2 years warranty.
- GO Lamps projector lamp
- Product Type
- Projector lamp - HS - 220 Watt
- OEM Manufacturer Lamp Equivalent
- Panasonic ET-LAB80
- Bulb life cycle
- 3000 hour(s)
- 2-year warranty
- Designed For
- Panasonic PT-LB75E, LB75NTE, LB75NTU, LB75U, LB80E, LB80NTE, LB80NTU, LB80U
- Product Type
- Projector lamp
Lamp
- HS
- Capacity
- 220 Watt
- Life Cycle
- 3000 hour(s)
- Limited warranty - 2 years
- Designed For
