Product
Go Lamp AJ-LT91 Lamp Module for LG RD-JT91
Quicklinx: 9WPVWS00 Mfr#: GL232
GO Lamp for AJ-LT91. Lamp module for LG RD-JT91 projectors. Type = NSH. Power = 200 Watts. Lamp Life = 2000 Hours. Alt part code = 6912B22008A.Now with 2 years warranty.
GO Lamps projector lamp
Projector lamp - NSH - 200 Watt
OEM Manufacturer Lamp Equivalent
6912B22008A, AJ-LT91
Bulb life cycle
2000 hour(s)
2 years warranty
LG RD JT90, JT91, JT92
Projector lamp
Lamp
NSH
200 Watt
Life Cycle
2000 hour(s)
