GO Lamp for 60003224. Lamp module for NEC PA600X/PA550W/PA500U Projector. Power = 330 Watts. Lamp life (Hours) = 3000 STD/4000 ECO. Alt part code = NP21LP. Now with 2 years warranty.
- GO Lamps projector lamp
- Product Type
- Projector lamp - 330 Watt
- OEM Manufacturer Lamp Equivalent
- NEC 60003224, NEC NP21LP
- Bulb life cycle
- 3000 hour(s) (standard mode) / 4000 hour(s) (economic mode)
- 2 years warranty
- Designed For
- NEC NP-PA500U, NP-PA500U-13ZL, NP-PA500X, NP-PA500X-13ZL, NP-PA550W, NP-PA550W-13ZL, NP-PA600X, NP-PA600X-13ZL, PA500U, PA500X, PA550W, PA600X
- Product Type
- Projector lamp
Lamp
- Capacity
- 330 Watt
- Life Cycle
- Limited warranty - 2 years
- Designed For
