Product
Go Lamp 5J.J2N05.011 Lamp Module for BenQ SP840
Quicklinx: 9WM3WS00 Mfr#: GL806
Type: Projector lamp kit
Stock Status: In Stock, Used Stock
Hurry, only 3 left in stock!
£165.76 ex VAT
£198.91 inc VAT
GO Lamp for 5J.J2N05.011. Lamp module for BENQ SP840 Projector. Power = 300 Watts, Lamp Life = 3000 Hours. Now with 2 years FOC warranty.
GO Lamps projector lamp kit
Projector lamp kit - 300 Watt
OEM Manufacturer Lamp Equivalent
BenQ 5J.J2N05.011
Bulb life cycle
3000 hour(s)
2 years warranty
BenQ SP840
Projector lamp kit
BenQ 5J.J2N05.011
Lamp
300 Watt
Life Cycle
3000 hour(s)
BenQ SP840
Used stock
What is used stock?
Accessories Packaging Functional Software Manuals
Ref: 9WM3 038750
Condition: This item has been opened. It is in excellent condition.
This part of the stock item is not applicable e.g. it might not include accessories or software as standard  This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is not applicable e.g. it might not include accessories or software as standard  This part of the stock item is present and in good condition  £22.12
Legend
  • This part of the stock item is present and in good conditionThis part of the stock item is present and in good condition
  • This part of the stock item is not present or functionalThis part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standardThis part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.This item has not been tested.
Brand: Go Lamp
Stock Status: Used Stock
Price Range Ex VAT: 150 - 300
