GA-Z97X-Gaming G1 WIFI-BK Intel® Z97 Chipset
- Extended server level 168 hour durability Test
- Supports 4th and 5th Generation Intel® Core™ processors
- Onboard Creative Sound Core3D™ quad-core audio processor
- AMP-UP Audio technology with exclusive Upgradable OP-AMP
- Audio Noise Guard with LED path lighting
- Dual DAC-UP USB ports
- Gold plated display and audio ports
- High end Nichicon audio capacitors
- Killer™ E2200 and Intel gaming networking
- Bluetooth 4.0+867Mbps 11AC dual band WIFI card
- Extreme gaming 4-way graphics support
- SATA Express support for 10 Gb/s data transfer
- Water block thermal design with G1/4 threaded fittings
- Long lifespan Durable Black Solid caps
- APP Center including EasyTune™ and Cloud Station™ utilities
- GIGABYTE UEFI DualBIOS™
Gigabyte AMP-UP Audio technology
Gigabyte G1 Gaming motherboards are equipped with the Gigabyte exclusive AMP-UP Audio technology, which provides the industry's highest level of onboard audio features and technologies. With Gigabyte AMP-UP Audio, gamers and audiophiles are able to experience crisp, ultra realistic sound effects while gaming, and the richest possible sound experience when listening to their favorite music and movies. -
Creative SBX Pro Studio audio suite
SBX Pro Studio suite of audio playback technologies deliver a new level of audio immersion. Realistic surround sound, the ability to clearly hear specific sounds in a gaming environment are just a few elements of SBX Pro Studio that enhances the overall experience, be it movies, games or music. -
High end audio capacitors
Gigabyte G1 Gaming motherboards use high end, Nichicon audio capacitors. These professional audio capacitors deliver the highest quality sound resolution and sound expansion to create the most realistic sound effects for professional gamers. -
Gold plated audio hardware
Gigabyte G1 Gaming motherboards pack top quality gold plated audio and HDMI connectors for improved connectivity and long lasting durability. Gold has superb signal conductivity and will not tarnish over extended periods of use. The Creative Sound Core3D processor is also shielded by a gold plated cover which eliminates electrostatic interference. -
Featuring dual USB 2.0 ports, Gigabyte USB DAC-UP provides clean, noise-free power delivery to your digital-to-analog converter. DACs can be sensitive to fluctuations in power from the other USB ports, which is why Gigabyte USB DAC-UP takes advantage of an isolated power source that minimizes potential fluctuations and ensures the best audio experience possible. -
No lag, just frag
Gigabyte G1 Gaming motherboards feature the Killer E2200 from Qualcomm Atheros, a high-performance, adaptive gigabit Ethernet controller that offers better online gaming and online media performance compared to standard solutions. -
Intel Gigabit LAN
Intel Gigabit LAN networking, a popular choice with gamers, delivers several performance-enhancing features such as advanced interrupt handling to help reduce CPU overhead and Jumbo Frame support for extra large data packets. -
Integrated 2T2R dual band IEEE802.11ac Wi-Fi + BT 4.0
This motherboard comes with an exclusive IEEE802.11ac Wi-Fi module that supports up to 867 Mbps wireless networks and Bluetooth 4.0. IEEE802.11ac Wi-Fi runs at up to 867 Mbit/s and the bundled 2.4 GHz/5 GHz dual-band, 2T2R antenna gives you wide coverage. -
Extreme multi-GPU support
Flexible graphics capabilities supported for either 4-way CrossFire or 4-way SLI action, delivering the ultimate in graphics performance for gaming enthusiasts who demand the highest frame rates without compromising on resolution. -
SATA Express connector
Gigabyte motherboards feature an onboard SATA Express connector which provides performance far superior to that of current SATA technologies. SATA Express features data transfer rates of up to 10 Gb/s, considerably higher than SATA Revision 3 (6 Gb/s), which won't bottleneck faster NAND flash technologies in cutting edge SSDs. SATA Express combines the benefits of PCI-Express and SATA to provide much higher bandwidth, allowing SATA Express based drives to perform at similar speeds as PCI-Express based drives. -
4K ultra HD support
4K resolution is the next technological milestone in high-definition content delivery, utilizing approximately 4,000 pixels on the horizontal axis, more than four times today's standard HD pixel density. Gigabyte motherboards provide native 4K support with integrated Intel HD Graphics via HDMI. -
HDMI - the next generation multimedia interface
HDMI is a high-definition multimedia interface which provides up to 5 Gb/s video transmitting bandwidth and 8-channel high quality audio all through a single cable. Able to transmit superior, uncompressed digital video and audio, HDMI ensures the crispest rendering of digital content up to 1080p without the quality losses associated with analog interfaces and their digital-to-analog conversion. In addition, HDMI is compatible with HDCP (high-bandwidth digital content protection), allowing the playback of Blu-ray/HD DVD and other protected media content. -
Gigabyte OPT fan support
Gigabyte 9 series motherboards feature OPT fan support, an additional CPU fan pin header that can be used to connect a water pump and configured for continuous full speed operation. The OPT fan is also useful for high performance coolers employing two fans. -
10K Durable Black soild caps
Gigabyte 9 series motherboards integrate the absolute best quality solid state capacitors that are rated to perform at maximum efficiency for a guaranteed minimum of 10K hours. Not only do they provide ultra-low ESR no matter how high the CPU loading, they also come in customized jet black from Nippon Chemi-Con and Nichicon. -
5x (15µ) gold plated CPU socket design
Gigabyte 9 series motherboards come equipped with a gold plated CPU socket, which means that enthusiasts can enjoy absolute reliability and longevity for the CPU socket overtime, without having any concerns about corroded pins and bad contacts.
- Gigabyte GA-Z97X-Gaming G1 WIFI-BK - Black Edition - 1.0 - motherboard - ATX - LGA1150 Socket - Z97
- Product Type
- Motherboard - ATX
- Chipset Type
- Intel Z97 Express
- Processor Socket
- 1 x LGA1150 Socket
- Compatible Processors
- Pentium, Celeron, Core i5, Core i3, Core i7
- Max RAM Size
- 32 GB
- RAM Supported
- 4 DIMM slots - DDR3, non-ECC
- Storage Ports
- 10 x SATA-600 (RAID), 1 x SATA Express port
- USB / FireWire Ports
- 6 x USB 3.0 + 2 x USB 2.0 + (2 x USB 3.0 + 6 x USB 2.0 via headers)
- Max Allocated RAM Size
- 1 GB
- Audio
- HD Audio (6-channel)
- LAN
- Bluetooth, 2 x Gigabit Ethernet, 802.11a/b/g/n/ac
- Product Type
- Motherboard - ATX
- Chipset Type
- Intel Z97 Express
- Processor Socket
- LGA1150 Socket
- Max Processors Qty
- 1
Supported RAM
- Max Size
- 32 GB
- Technology
- DDR3
- Bus Clock
- 1600 MHz, 1333 MHz, 2800 MHz (O.C.), 2933 MHz (O.C.), 2666 MHz (O.C.), 2600 MHz (O.C.), 2500 MHz (O.C.), 2400 MHz (O.C.), 2200 MHz (O.C.), 2133 MHz (O.C.), 2000 MHz (O.C.), 1866 MHz (O.C.), 1800 MHz (O.C.), 3000 MHz (O.C.), 3100 MHz (O.C.), 3200 MHz (O.C.)
- Supported RAM Integrity Check
- Non-ECC
- Dual channel memory architecture, Intel Extreme Memory Profiles (XMP)
Graphics
- 1 GB
Audio
- Audio Codec
- Creative Sound Core3D
- High Definition Audio
LAN
- Network Interfaces
- Expansion Slots
- 1 x CPU , 4 x DIMM 240-pin , 2 x PCIe 3.0 x16 (x16 mode (x8 mode if all PCI Express 3.0 x8 slots are occupied)) , 2 x PCIe 3.0 x16 (x8 mode) , 3 x PCIe 2.0 x1
- Storage Interfaces
- SATA-600 -connectors: 6 x 7pin SATA, 1 x SATA Express port - 6 devices - RAID 0 / RAID 1 / RAID 10 / RAID 5 , Marvell 88SE9172: SATA-600 -connectors: 4 x 7pin Serial ATA - 4 devices - RAID 0 / RAID 1
- RAID Features
- Intel Smart Response Technology
- 2 x LAN (Gigabit Ethernet) , 2 x USB 2.0 , 1 x HDMI , 6 x USB 3.0 , 1 x DisplayPort , 1 x audio line-out - mini-jack , 1 x audio line-in - mini-jack , 1 x microphone - mini-jack , 1 x audio line-out (rear) - mini-jack , 1 x audio line-out (center/subwoofer) - mini-jack , 1 x TOSLINK , 1 x PS/2 keyboard / mouse , 1 x DVI-I
- Internal Interfaces
- 6 x USB 2.0 - header , 2 x USB 3.0 - header , 1 x audio - header
- Power Connectors
- 24-pin main power connector, 8-pin ATX12V connector
- BIOS Type
- AMI
- BIOS Features
- WfM 2.0 support, UEFI BIOS, SMBIOS 2.7 support, DMI 2.7 support, ACPI 5.0 support, Dual BIOS
- Hardware Monitoring
- CPU core temperature, chassis temperature, CPU fan tachometer, chassis fan tachometer, system voltage, CPU overheating protection
- Hardware Features
- Q-Flash, NVIDIA 3-way SLI Technology Support, Intel Extreme Memory Profile (XMP) support, NVIDIA 2-way SLI Technology Support, On/Off Charge, Intel Smart Response Technology, Fanless Design Heatsink, NVIDIA 4-way SLI Technology Support, AMD CrossFireX technology support, AMD 3-way CrossFireX technology support, Intel Rapid Start Technology, Intel Smart Connect Technology, AMD 4-way CrossFireX technology support, GIGABYTE OPT Fan Support, GIGABYTE AMP-UP Audio, Gold Plated Audio Hardware, Black Solid Capacitors, GIGABYTE USB DAC-UP, upgradable OP-AMP, GIGABYTE Smart Switch, TI Burr Brown OPA2134 operational amplifier
- Software Included
- Norton Internet Security, @BIOS, EasyTune, Cloud Station, GIGABYTE EZ Setup, Xpress Install, GIGABYTE USB Blocker, GIGABYTE App Center, Smart TimeLock, SBX Pro Studio, GIGABYTE Fast Boot
- Plug and Play, ACPI 5.0
- 30.5 cm
- 24.4 cm
