Gigabyte Z370 AORUS Gaming K3 Intel Z370 S1151 DDR4 M.2 USB3.1G2 ATX
Quicklinx: D5D7WS00 Mfr#: Z370 AORUS Gaming K3
Marketing description is not available.
  • Smart headphone AMP
    It automatically detects impedance of your head-worn audio device, whether earbuds or high-end headphones to provide optimal audio dynamics - preventing issues such as low volume and distortion.
  • High-end WIMA & audio capacitors
    The AORUS Z370 motherboards boast a combination of Hi-Fi grade WIMA FKP2 capacitors and audio grade fine gold capacitors. While the fine gold capacitors are suited for high-grade audio equipment, using state of the art technology to provide rich sound in the bass and clearer high frequencies, the WIMA FKP2 capacitors are being used widely in premium grade Hi-Fi systems. The addition of this to the exclusive AORUS AMP-UP Audio technology makes for the ideal onboard sound solution for demanding audiophiles.
  • Smart Fan 5
    With Smart Fan 5 users can ensure that their gaming PC can maintain its performance while staying cool. Smart Fan 5 allows users to interchange their fan headers to reflect different thermal sensors at different locations on the motherboard. Not only that, with Smart Fan 5 more hybrid fan headers that support both PWM and voltage mode fans have been introduced to make the motherboard more liquid cooling friendly.
Gigabyte Z370 AORUS Gaming K3 - 1.0 - motherboard - ATX - LGA1151 Socket - Z370
Motherboard - ATX
Chipset Type
Intel Z370
Processor Socket
1 x LGA1151 Socket
Compatible Processors
Core i5, Core i3, Core i7 (supports 8th Generation Intel Core i3 / i5 / i7)
Max RAM Size
64 GB
RAM Supported
4 DIMM slots - DDR4, non-ECC, ECC (operate in non-ECC mode), unbuffered
Storage Ports
6 x SATA-600 (RAID), 2 x M.2
USB / FireWire Ports
1 x USB-C Gen 2 + 1 x USB 3.1 Gen 2 + 4 x USB 3.1 Gen 1 + 2 x USB 2.0 + (4 x USB 3.1 Gen 1 + 4 x USB 2.0 via headers)
Max Allocated RAM Size
1 GB
Audio
HD Audio (8-channel)
LAN
Gigabit Ethernet
Motherboard - ATX
Chipset Type
Intel Z370
Processor Socket
LGA1151 Socket
Max Processors Qty
1
Supported RAM
Max Size
64 GB
DDR4
Bus Clock
2400 MHz, 2133 MHz, 2666 MHz, 2800 MHz (O.C.), 3000 MHz (O.C.), 3200 MHz (O.C.), 3300 MHz (O.C.), 3400 MHz (O.C.), 3333 MHz (O.C.), 3466 MHz (O.C.), 3733 MHz (O.C.), 3600 MHz (O.C.), 3800 MHz (O.C.), 3666 MHz (O.C.), 3866 MHz (O.C.), 4000 MHz (O.C.)
Supported RAM Integrity Check
Non-ECC, ECC (operate in non-ECC mode)
Registered or Buffered
Unbuffered
Dual channel memory architecture, Intel Extreme Memory Profiles (XMP), supported ECC modules operate in non-ECC mode
Graphics
1 GB
Audio
Audio Codec
Realtek ALC1220
High Definition Audio
LAN
Network Interfaces
Gigabit Ethernet
Expansion Slots
1 x CPU , 4 x DIMM 288-pin , 1 x PCIe 3.0 x16 , 1 x PCIe 3.0 x16 (x4 mode) , 4 x PCIe 3.0 x1
Storage Interfaces
SATA-600 -connectors: 6 x 7pin Serial ATA - RAID 0 / RAID 1 / RAID 10 / RAID 5 , SATA-600 / PCIe 3.0 -connectors: 1 x M.2 , PCIe 3.0 -connectors: 1 x M.2
1 x LAN (Gigabit Ethernet) , 1 x HDMI , 1 x PS/2 keyboard / mouse , 1 x audio line-out (side surround) - mini-jack , 1 x audio line-out - mini-jack , 1 x audio line-in - mini-jack , 1 x microphone - mini-jack , 1 x audio line-out (rear) - mini-jack , 1 x audio line-out (center/subwoofer) - mini-jack , 1 x USB 3.1 Gen 2 , 4 x USB 3.1 Gen 1 , 2 x USB 2.0 , 1 x DVI-D , 1 x USB-C Gen2
Internal Interfaces
4 x USB 2.0 - header , 4 x USB 3.1 Gen 1 - header , 1 x audio - header , 1 x SPDIF out - header
Power Connectors
24-pin main power connector, 8-pin ATX12V connector
BIOS Type
AMI
BIOS Features
WfM 2.0 support, UEFI BIOS, SMBIOS 2.7 support, DMI 2.7 support, ACPI 5.0 support, Dual BIOS
Hardware Monitoring
CPU core temperature, chassis temperature, CPU fan tachometer, chassis fan tachometer, system voltage, CPU overheating protection, water cooling flow rate
Hardware Features
AutoGreen, On/Off Charge, Ultra Durable, AMD CrossFireX technology support, AMD Quad CrossFireX technology support, Easy RAID Installer, GIGABYTE AMP-UP Audio, Audio Noise Guard, GIGABYTE Double Locking Bracket, Anti-Sulfur Design, Intel Optane Memory Ready, GIGABYTE Smart Fan 5, RGB FUSION, Ultra Durable PCIe Armor, RGBW/-UV LED strips support
Software Included
Norton Internet Security, @BIOS, EasyTune, Cloud Station, Xpress Install, GIGABYTE USB Blocker, GIGABYTE App Center, cFosSpeed, Smart TimeLock, GIGABYTE Fast Boot, GIGABYTE V-Tuner, GIGABYTE Smart Keyboard, GIGABYTE Smart Backup, GIGABYTE Smart Fan 5, GIGABYTE 3D OSD
Plug and Play, HDCP 2.2
30.5 cm
24.4 cm
