GIGABYTE Gaming Motherboard - Z170X-Gaming 7
• Supports 6th Generation Intel® Core™ Processor
• Dual Channel DDR4, 4 DIMMs
• Intel® USB 3.1 with USB Type-C™ - the world's next Universal connector
• 3-Way Graphics Support with Exclusive Ultra Durable Metal Shielding over the PCIe Slots
• Dual PCIe Gen3 x4 M.2 Connectors with up to 32Gb/s Data Transfer (PCIe & SATA SSD support)
• 3 SATA Express Connectors for up to 16Gb/s Data Transfer
• 115dB SNR HD Audio with Built-in Rear Audio Amplifier
• Killer™ E2200 Gaming Networks
• High Quality Audio Capacitors and Audio Noise Guard with LED Trace Path Lighting
• APP Center Including EasyTune™ and Cloud Station™ Utilities
• GIGABYTE UEFI DualBIOS™ Technology
Extreme Intel® USB 3.1 Controller
The Intel® USB 3.1 controller utilizes 2 PCIe Gen3 lanes, offering 16 Gb/s of total bandwidth, for uncompromised transfer speeds of up to 10 Gb/s per USB 3.1. With twice the bandwidth compared to its previous generation, and backwards compatibility with USB 2.0 and 3.0, the much improved USB 3.1 protocol is available over the new reversible USB Type-C™ and the traditional USB Standard-A connector for better compatibility over a wider range of devices.
Connecting the Future - USB Type-C™
The World's Next Universal Connector - Reversible USB Type-C™ with USB 3.1
The USB Type-C™ is a new reversible connector that is loaded with useful features such as USB 3.1 support for 10 Gb/s transfer speed and DisplayPort 1.2 support to connect 4K monitors. Powered by the Intel® controller, this little port is the better USB Type-C™.
Realtek ALC1150 115dB SNR HD Audio
The ALC1150 is a high-performance multi-channel High Definition Audio Codec that delivers an exceptional audio listening experience with up to 115dB SNR, ensuring users get the best possible audio quality from their PC.
The ALC1150 provides ten DAC channels that simultaneously support 7.1-channel sound playback, plus 2 channels of independent stereo sound output (multiple streaming) through the front panel stereo outputs. Two stereo ADCs are integrated and can support a microphone array with Acoustic Echo Cancellation (AEC), Beam Forming (BF), and Noise Suppression (NS) technologies. The ALC1150 incorporates Realtek proprietary converter technology to achieve Front differential output 115dB Signal-to-Noise ratio (SNR) playback (DAC) quality and 104dB SNR recording (ADC) quality.
Additional Sound Blaster X-Fi MB3
GIGABYTE G1™ Gaming motherboards also include Sound Blaster X-Fi MB3 software suite. Sound Blaster X-Fi MB3 software suite is a powerful audio platform offering premium audio quality, effects and features for gamers. It features SBX Pro Studio™ suite of technologies, which is designed to give you the fullest audio experience.
Clean, low-noise power for your Digital-to-Analog Audio converter
GIGABYTE USB DAC-UP provides clean, noise-free power delivery to your Digital-to-Analog Converter. DACs can be sensitive to fluctuations in power from the other USB ports, which is why GIGABYTE USB DAC-UP takes advantage of an isolated power source that minimizes potential fluctuations and ensures the best audio experience possible.
GIGABYTE G1™ Gaming motherboards feature the Killer™ E2200 from Qualcomm Atheros, a high-performance, adaptive gigabit Ethernet controller that offers better online gaming and online media performance compared to standard solutions.
2-Way SLI™/3-Way CrossFire™ Multi-Graphics
Multi-graphics configuration offers better graphics performance for gaming enthusiasts who demand the highest frame rates without compromising on resolution.
With two PCIe Gen3 x4 M.2 connectors onboard, GIGABYTE brings to the user PCI-Express connectivity for SSD devices. Delivering up to 32 Gb/s data transfer speed per connector, the dual M.2 provides an ideal storage solution as it also supports RAID modes.
Next Generation SATA Express
SATA Express combines the benefits of PCI Express and SATA to provide much higher bandwidth, featuring data transfer rates of up to 16Gb/s.
All New GIGABYTE™ App Center Including EasyTune™, Cloud Station™ Utilities and More
GIGABYTE's EasyTune™ is a simple and easy-to-use interface that allows users to fine-tune their system settings or adjust system and memory clocks and voltages in a Windows environment. With Smart Quick Boost, one click is all it takes to automatically overclock your system, giving an added performance boost when you need it the most.
4K Ultra HD Support
4K resolution is the next technological milestone in high-definition content delivery, utilizing approximately 4,000 pixels on the horizontal axis, more than four times today's standard HD pixel density. GIGABYTE motherboards provide native 4K support with integrated Intel® HD Graphics via HDMI.
Extreme USB 3.1 controller
The USB 3.1 controller utilizes 2 PCIe Gen3 lanes, offering 16 Gb/s of total bandwidth, for uncompromised transfer speeds of up to 10 Gb/s per USB 3.1. With twice the bandwidth compared to its previous generation, and backwards compatibility with USB 2.0 and 3.0, the much improved USB 3.1 protocol is available over the reversible USB Type-C and the traditional USB Standard-A connector for better compatibility over a wider range of devices. -
Reversible USB type-C with USB 3.1
The USB Type-C is a reversible connector that is loaded with useful features such as USB 3.1 support for 10 Gb/s transfer speed and DisplayPort 1.2 support to connect 4K monitors. Powered by the Intel controller, this little port is the better USB Type-C. -
Realtek ALC1150 115dB SNR HD audio
The ALC1150 is a high-performance multi-channel High Definition Audio Codec that delivers an exceptional audio listening experience with up to 115dB SNR, ensuring users get the best possible audio quality from their PC. -
High end audio capacitors
Gigabyte G1 Gaming motherboards use high end, Japanese branded Nichicon audio capacitors. These professional audio capacitors deliver the highest quality sound resolution and sound expansion to create the most realistic sound effects for professional gamers. -
Killer E2200 gaming network
Gigabyte G1 Gaming motherboards feature the Killer E2200 from Qualcomm Atheros, a high-performance, adaptive gigabit Ethernet controller that offers better online gaming and online media performance compared to standard solutions. -
2-Way SLI /3-Way CrossFire Multi-Graphics
Multi-graphics configuration offers better graphics performance for gaming enthusiasts who demand the highest frame rates without compromising on resolution. -
Ultra durable PCIe metal shielding
The innovative one piece stainless steel shielding design from Gigabyte reinforces the PCIe connectors to provide the extra strength required to support heavy graphics cards. -
With two PCIe Gen3 x4 M.2 connectors onboard, Gigabyte brings to the user PCI-Express connectivity for SSD devices. Delivering up to 32 Gb/s data transfer speed per connector, the dual M.2 provides an ideal storage solution as it also supports RAID modes. -
Next generation SATA express
SATA Express combines the benefits of PCI Express and SATA to provide much higher bandwidth, featuring data transfer rates of up to 16Gb/s. -
Easy tune
Get the highest levels of performance from your PC with easy to use GIGABYTE overclocking features. -
15 gold plated CPU socket design
Gigabyte motherboards come equipped with a 15 micron thick gold plated CPU socket, which means that enthusiasts can enjoy absolute reliability and longevity for the CPU socket overtime, without having any concerns about corroded pins or bad contacts. -
4K Ultra HD support
4K resolution is the next technological milestone in high-definition content delivery, utilizing approximately 4,000 pixels on the horizontal axis, more than four times today's standard HD pixel density. GIGABYTE motherboards provide native 4K support with integrated Intel HD Graphics via HDMI. -
HDMI - the next generation multimedia interface
HDMI is a High-Definition Multimedia Interface which provides up to 5Gb/s video transmitting bandwidth and 8-channel high quality audio all through a single cable. Able to transmit superior, uncompressed digital video and audio, HDMI ensures the crispest rendering of digital content up to 1080p without the quality losses associated with analog interfaces and their digital-to-analog conversion. In addition, HDMI is compatible with HDCP (High-bandwidth Digital Content Protection), allowing the playback of Blu-ray/HD DVD and other protected media content.
- Gigabyte GA-Z170X-Gaming 3 - 1.0 - motherboard - ATX - LGA1151 Socket - Z170
- Product Type
- Motherboard - ATX
- Chipset Type
- Intel Z170
- Processor Socket
- 1 x LGA1151 Socket
- Compatible Processors
- Pentium, Celeron, Core i5, Core i3, Core i7
- Max RAM Size
- 64 GB
- RAM Supported
- 4 DIMM slots - DDR4, non-ECC, ECC, unbuffered
- Storage Ports
- 6 x SATA-600 (RAID), 3 x SATA Express port, 2 x M.2
- USB / FireWire Ports
- 1 x USB-C + 1 x USB 3.1 + 3 x USB 3.0 + 2 x USB 2.0 + (4 x USB 3.0 + 4 x USB 2.0 via headers)
- Max Allocated RAM Size
- 512 MB
- Audio
- HD Audio (8-channel)
- LAN
- Gigabit Ethernet
- 3-year warranty
- Product Type
- Motherboard - ATX
- Chipset Type
- Intel Z170
- Processor Socket
- LGA1151 Socket
- Max Processors Qty
- 1
Supported RAM
- Max Size
- 64 GB
- Technology
- DDR4
- Bus Clock
- 2133 MHz, 2800 MHz (O.C.), 2666 MHz (O.C.), 2400 MHz (O.C.), 3000 MHz (O.C.), 3200 MHz (O.C.), 3300 MHz (O.C.), 3400 MHz (O.C.), 3333 MHz (O.C.), 3466 MHz (O.C.)
- Supported RAM Integrity Check
- Non-ECC, ECC
- Registered or Buffered
- Unbuffered
- Dual channel memory architecture, Intel Extreme Memory Profiles (XMP)
Graphics
- 512 MB
Audio
- Audio Codec
- Realtek ALC1150
- High Definition Audio
LAN
- Network Controller
- Killer Gaming E2201
- Network Interfaces
- Gigabit Ethernet
- Expansion Slots
- 1 x CPU , 4 x DIMM 288-pin , 1 x PCIe 3.0 x16 (x16 mode (x8 mode if neighbour slot is occupied)) , 1 x PCIe 3.0 x16 (x8 mode) , 1 x PCIe 3.0 x16 (x4 mode) , 3 x PCIe 3.0 x1
- Storage Interfaces
- SATA-600 -connectors: 6 x 7pin SATA, 2 x M.2, 3 x SATA Express port - RAID 0 / RAID 1 / RAID 10 / RAID 5
- RAID Features
- Intel Smart Response Technology
- 1 x LAN (Gigabit Ethernet) , 2 x USB 2.0 , 1 x HDMI , 3 x USB 3.0 , 1 x VGA , 1 x audio line-out - mini-jack , 1 x audio line-in - mini-jack , 1 x microphone - mini-jack , 1 x audio line-out (rear) - mini-jack , 1 x audio line-out (center/subwoofer) - mini-jack , 1 x PS/2 keyboard / mouse , 1 x DVI-D , 1 x USB 3.1 , 1 x USB-C , 1 x TOSLINK
- Internal Interfaces
- 4 x USB 2.0 - header , 4 x USB 3.0 - header , 1 x audio - header , 1 x SPDIF out - header , 1 x serial - header
- Power Connectors
- 24-pin main power connector, 8-pin ATX12V connector
- BIOS Type
- AMI
- BIOS Features
- WfM 2.0 support, UEFI BIOS, SMBIOS 2.7 support, DMI 2.7 support, ACPI 5.0 support, Dual BIOS
- Hardware Monitoring
- CPU core temperature, chassis temperature, CPU fan tachometer, chassis fan tachometer, system voltage, CPU overheating protection
- Hardware Features
- Q-Flash, NVIDIA SLI Technology Support, AutoGreen, Intel Extreme Memory Profile (XMP) support, Intel Smart Response Technology, Ultra Durable, AMD CrossFireX technology support, AMD 3-way CrossFireX technology support, Easy RAID Installer, 4K Ultra HD ready, Audio Noise Guard with Path Lighting, GIGABYTE USB DAC-UP, upgradable OP-AMP, TI Burr Brown OPA2134 operational amplifier, Turbo B-Clock
- Software Included
- Norton Internet Security, @BIOS, EasyTune, Cloud Station, Xpress Install, GIGABYTE USB Blocker, GIGABYTE App Center, Smart TimeLock, GIGABYTE Fast Boot, Creative Sound Blaster X-Fi MB3
- Plug and Play, ACPI 5.0
- 30.5 cm
- 23.5 cm
- Limited warranty - parts and labour - 3 years
