Z170-HD3P
• Supports 6th Generation Intel® Core™ Processor
• Dual Channel DDR4, 4 DIMMs
• Fast USB 3.1 with USB Type-C™ - the world's next Universal connector
• 2-Way Graphics with Premium PCIe Lane
• PCIe Gen3 x4 M.2 Connector with up to 32Gb/s Data Transfer (PCIe & SATA SSD support)
• 3 SATA Express Connectors for up to 16Gb/s Data Transfer
• 8-channel HD Audio with High Quality Audio Capacitors
• Audio Noise Guard with LED Trace Path Lighting
• Realtek® Green GbE LAN with cFosSpeed Internet Accelerator Software
• APP Center Including EasyTune™ and Cloud Station™ Utilities
• GIGABYTE UEFI DualBIOS™ Technology
GIGABYTE Ultra Durable ™ Motherboards
GIGABYTE 100 series motherboards support the latest 6th Generation Intel® Core™ processors, a 14nm desktop CPU which features improved performance, power efficiency and support for DDR4 memory, bringing cutting edge features and ultimate performance to your next PC build.
Fast USB 3.1 Solution
The latest USB 3.1 offers a staggering 10Gb/s transfer speed, 2x faster than USB 3.0 and backward compatibility with existing USB devices.
Connecting the Future - USB Type-C™ - The World's Next Universal Connector
The USB Type-C™ port with USB 3.1 support is a robust and slim connector for all of your devices with reversible plug orientation
Fast Onboard Storage with 32Gb/s M.2
GIGABYTE M.2 solution offers considerably faster storage performance and support for both PCIe and SATA interface for M.2 SSD devices.
All New GIGABYTE App Center Including EasyTune™, Cloud Station™ Utilities and More
GIGABYTE's EasyTune™ is a simple and easy-to-use interface that allows users to fine-tune their system settings or adjust system and memory clocks and voltages in a Windows environment. With Smart Quick Boost, one click is all it takes to automatically overclock your system, giving an added performance boost when you need it the most.
Next Generation SATA Express
SATA Express combines the benefits of PCI Express and SATA to provide much higher bandwidth, featuring data transfer rates of up to 16Gb/s.
2-Way CrossFire™ Multi-Graphics
Multi-graphics configuration offers better graphics performance for gaming enthusiasts who demand the highest frame rates without compromising on resolution
Realtek Green GbE with cFosSpeed Internet Accelerator Software
Realtek RTL8111HS Green GbE features cFosSpeed, a network traffic management application which helps to improve network latency, maintain low ping times to delivery better responsiveness in a crowded LAN environments. Realtek Green GbE consumes significant less power when it’s in idle state in comparison with others.
15 Gold Plated CPU Socket Design
GIGABYTE motherboards come equipped with a 15 micron thick gold plated CPU socket*, which means that enthusiasts can enjoy absolute reliability and longevity for the CPU socket overtime, without having any concerns about corroded pins or bad contacts.
GIGABYTE Patented DualBIOS™ (UEFI) Design
GIGABYTE Ultra Durable™ motherboards feature GIGABYTE DualBIOS™, an exclusive technology from GIGABYTE that protects arguably one of your PC's most crucial components, the BIOS. GIGABYTE DualBIOS™ means that your motherboard has both a 'Main BIOS' and a 'Backup BIOS', making users protected from BIOS failure due to virus attack, hardware malfunction, improper OC settings or power failure during the update process.
4K Ultra HD Support
4K resolution is the next technological milestone in high-definition content delivery, utilizing approximately 4,000 pixels on the horizontal axis, more than four times today's standard HD pixel density. GIGABYTE motherboards provide native 4K support with integrated Intel® HD Graphics via HDMI.
Gigabyte ultra durable motherboards
Gigabyte 100 series motherboards support the latest 6th Generation Intel Core processors, a 14nm desktop CPU which features improved performance, power efficiency and support for DDR4 memory, bringing cutting edge features and ultimate performance to your next PC build. -
Fast USB 3.1 solution
Fast USB 3.1 offers a staggering 10Gb/s transfer speed, 2x faster than USB 3.0 and backward compatibility with existing USB devices. -
Fast onboard storage with 32Gb/s M.2
Gigabyte M.2 solution offers considerably faster storage performance and support for both PCIe and SATA interface for M.2 SSD devices. -
Easy tune
Get the highest levels of performance from your PC with easy to use Gigabyte overclocking features. -
Next generation SATA express
SATA Express combines the benefits of PCI Express and SATA to provide much higher bandwidth, featuring data transfer rates of up to 16Gb/s. -
2-Way CrossFire multi-graphics
Multi-graphics configuration offers better graphics performance for gaming enthusiasts who demand the highest frame rates without compromising on resolution. -
15 Gold plated CPU socket design
Gigabyte motherboards come equipped with a 15 micron thick gold plated CPU socket, which means that enthusiasts can enjoy absolute reliability and longevity for the CPU socket overtime, without having any concerns about corroded pins or bad contacts. -
Gigabyte patented DualBIOS (UEFI) design
Gigabyte Ultra Durable motherboards feature Gigabyte DualBIOS, an exclusive technology from Gigabyte that protects arguably one of your PC's most crucial components, the BIOS. Gigabyte DualBIOS means that your motherboard has both a 'Main BIOS' and a 'Backup BIOS', making users protected from BIOS failure due to virus attack, hardware malfunction, improper OC settings or power failure during the update process. -
4K Ultra HD support
4K resolution is the next technological milestone in high-definition content delivery, utilizing approximately 4,000 pixels on the horizontal axis, more than four times today's standard HD pixel density. Gigabyte motherboards provide native 4K support with integrated Intel HD Graphics via HDMI. -
HDMI - the next generation multimedia interface
HDMI is a High-Definition Multimedia Interface which provides up to 5Gb/s video transmitting bandwidth and 8-channel high quality audio all through a single cable. Able to transmit superior, uncompressed digital video and audio, HDMI ensures the crispest rendering of digital content up to 1080p without the quality losses associated with analog interfaces and their digital-to-analog conversion. In addition, HDMI is compatible with HDCP (High-bandwidth Digital Content Protection), allowing the playback of Blu-ray/HD DVD and other protected media content.
- Gigabyte GA-Z170-HD3P - 1.0 - motherboard - ATX - LGA1151 Socket - Z170
- Product Type
- Motherboard - ATX
- Chipset Type
- Intel Z170
- Processor Socket
- 1 x LGA1151 Socket
- Compatible Processors
- Pentium, Celeron, Core i5, Core i3, Core i7
- Max RAM Size
- 64 GB
- RAM Supported
- 4 DIMM slots - DDR4, non-ECC, unbuffered
- Storage Ports
- 6 x SATA-600 (RAID), 3 x SATA Express port, 1 x M.2
- USB / FireWire Ports
- 1 x USB-C + 1 x USB 3.1 + 3 x USB 3.0 + 2 x USB 2.0 + (4 x USB 3.0 + 4 x USB 2.0 via headers)
- Max Allocated RAM Size
- 512 MB
- Audio
- HD Audio (8-channel)
- LAN
- Gigabit Ethernet
- Product Type
- Motherboard - ATX
- Chipset Type
- Intel Z170
- Processor Socket
- LGA1151 Socket
- Max Processors Qty
- 1
Supported RAM
- Max Size
- 64 GB
- Technology
- DDR4
- Bus Clock
- 2133 MHz, 3200 MHz (O.C.)
- Supported RAM Integrity Check
- Non-ECC
- Registered or Buffered
- Unbuffered
- Dual channel memory architecture, Intel Extreme Memory Profiles (XMP)
Graphics
- 512 MB
Audio
- Audio Codec
- Realtek ALC887
- High Definition Audio
LAN
- Network Interfaces
- Gigabit Ethernet
- Expansion Slots
- 1 x CPU , 4 x DIMM 288-pin , 1 x PCIe 3.0 x16 , 1 x PCIe 3.0 x16 (x4 mode) , 2 x PCIe 3.0 x1 , 2 x PCI
- Storage Interfaces
- SATA-600 -connectors: 6 x 7pin SATA, 1 x M.2, 3 x SATA Express port - RAID 0 / RAID 1 / RAID 10 / RAID 5
- RAID Features
- Intel Smart Response Technology
- 1 x LAN (Gigabit Ethernet) , 2 x USB 2.0 , 1 x HDMI , 3 x USB 3.0 , 1 x VGA , 1 x audio line-out - mini-jack , 1 x audio line-in - mini-jack , 1 x microphone - mini-jack , 1 x audio line-out (rear) - mini-jack , 1 x audio line-out (center/subwoofer) - mini-jack , 1 x audio line-out (side surround) - mini-jack , 1 x PS/2 keyboard / mouse , 1 x DVI-D , 1 x USB 3.1 , 1 x USB-C
- Internal Interfaces
- 4 x USB 2.0 - header , 4 x USB 3.0 - header , 1 x audio - header , 1 x SPDIF out - header , 1 x serial - header , 1 x parallel - header
- Power Connectors
- 24-pin main power connector, 8-pin ATX12V connector
- BIOS Type
- AMI
- BIOS Features
- WfM 2.0 support, UEFI BIOS, SMBIOS 2.7 support, DMI 2.7 support, ACPI 5.0 support, Dual BIOS
- Hardware Monitoring
- CPU core temperature, chassis temperature, CPU fan tachometer, chassis fan tachometer, system voltage, CPU overheating protection
- Hardware Features
- Q-Flash, AutoGreen, Intel Extreme Memory Profile (XMP) support, Intel Smart Response Technology, Ultra Durable, AMD CrossFireX technology support, Easy RAID Installer, 4K Ultra HD ready, Audio Noise Guard with Path Lighting, GIGABYTE Smart Switch
- Software Included
- Norton Internet Security, @BIOS, EasyTune, Cloud Station, Xpress Install, GIGABYTE USB Blocker, GIGABYTE App Center, cFosSpeed, Smart TimeLock, GIGABYTE Fast Boot
- Plug and Play, ACPI 5.0
- 30.5 cm
- 19.9 cm
