Ambient Surround LED
Set the Color that Matches Your Style
Now offering more LED customizations than ever, users can truly adapt their PC to represent their lifestyle. With full RGB support and a redesigned Ambient LED application, the user has complete control over the LEDs which surround the motherboard.
Light Up Your Case to Match your Motherboard
With an onboard Pin Header for aftermarket LED Strips, users now have the ability to sync the lighting in their computer case with the lighting on their motherboard. By using the Ambient LED Application, included in GIGABYTE APP Center, users are also able to specify the lighting modes available and ensure that everything is illuminating their system in harmony.
Dual Hybrid Fan Headers
Precise PWM and Voltage Control for Water pumps or Fans
Many of today’s modern computers feature water cooling to ensure that the CPU or graphics cards stay cool and quiet while they are put under heavy load. In order to provide the best support for water cooling solutions, GIGABYTE has equipped its X99/Z170 motherboards with an additional water pump power header. This allows the user to have full control over two water pumps or fans. An additional benefit of these headers with GIGABYTE’s motherboards is the option to choose between voltage calibration or PWM modes.
Immersive VR
Gaming Experience
- VR requires 30% more performance than Full HD graphics for a steady 60FPS or greater.
- Only Gaming PCs can provide the best VR experience.
To create a seamless VR experience GIGABYTE Motherboards offer the best features to make your virtual reality feel like your actual reality.
With technologies such as Thunderbolt™ 3 to transfer data and video, NVMe support via M.2 or U.2, and a one piece metal shielding to brace for heavier discrete graphics cards its obvious that GIGABYTE has the tools you need to start your journey in VR. To set the mood GIGABYTE Motherboards include Ambient Surround LED to put you in the center of action.
*2-Way SLI™ / CrossFire™ Multi-Graphics *
Multi-graphics configuration offers better graphics performance for gaming enthusiasts who demand the highest frame rates without compromising on resolution.
Light up your case to match your motherboard
With an onboard Pin Header for aftermarket LED Strips, users now have the ability to sync the lighting in their computer case with the lighting on their motherboard. By using the Ambient LED Application, included in GIGABYTE APP Center, users are also able to specify the lighting modes available and ensure that everything is illuminating their system in harmony. -
Precise PWM and voltage control for water pumps or fans
Many of today's modern computers feature water cooling to ensure that the CPU or graphics cards stay cool and quiet while they are put under heavy load. In order to provide the best support for water cooling solutions, GIGABYTE has equipped its X99/Z170 motherboards with an additional water pump power header. This allows the user to have full control over two water pumps or fans. An additional benefit of these headers with GIGABYTE's motherboards is the option to choose between voltage calibration or PWM modes. -
NVMe performance for PCIe SSDs
The Intel 750 series SSDs offer an incredible increase in performance over SATA drives. Using the NVMe protocol which takes advantage of the fast bandwidth of PCIe Gen3 x4 lanes (32 Gb/s), the drives are a clear advantage for users looking to boot their OS faster, load their games in a flash and access large files without waiting. By implementing the U.2 port onboard to support the 2.5" Intel 750 series drive, GIGABYTE ensures that the users can benefit from the best performance. -
Genuine all digital power design
GIGABYTE X99 series motherboards use an all digital CPU power design from International Rectifier which includes both 4th Generation digital PWM Controllers and industry-leading 3rd Generation PowIRstage controllers. These 100% digital controllers offer incredible precision in delivering power to the motherboard's most power-hungry and energy-sensitive components, allowing enthusiasts to get the absolute maximum performance from their Intel Core i7 Extreme Edition CPUs. -
Support for DDR4 XMP up to 3400 MHz and beyond
GIGABYTE is offering a tested and proven platform that ensures proper compatibility with profiles up to 3400 MHz and beyond. All users need to do to attain this performance boost is to ensure that their memory module is XMP capable and that the XMP function is activated and enabled on their GIGABYTE motherboard.
- Gigabyte GA-X99-Ultra Gaming - 1.0 - motherboard - ATX - LGA2011-v3 Socket - X99
- Product Type
- Motherboard - ATX
- Chipset Type
- Intel X99 Express
- Processor Socket
- 1 x LGA2011-v3 Socket
- Compatible Processors
- Core i7 Extreme Edition, Core i7
- Max RAM Size
- 256 GB
- RAM Supported
- 8 DIMM slots - DDR4, non-ECC, registered, unbuffered
- Storage Ports
- 6 x SATA-600 (RAID), 4 x SATA-600, 1 x SATA Express port, 1 x M.2, 1 x U.2 port
- USB / FireWire Ports
- 1 x USB-C + 1 x USB 3.1 + 6 x USB 3.0 + (4 x USB 3.0 + 4 x USB 2.0 via headers)
- Audio
- HD Audio (8-channel)
- LAN
- 2 x Gigabit Ethernet
- Product Type
- Motherboard - ATX
- Chipset Type
- Intel X99 Express
- Processor Socket
- LGA2011-v3 Socket
- Max Processors Qty
- 1
Supported RAM
- Max Size
- 256 GB
- Technology
- DDR4
- Bus Clock
- 2133 MHz, 2800 MHz (O.C.), 2666 MHz (O.C.), 2400 MHz (O.C.), 3000 MHz (O.C.), 3200 MHz (O.C.), 3400 MHz (O.C.), 3333 MHz (O.C.), 3600 MHz (O.C.)
- Supported RAM Integrity Check
- Non-ECC
- Registered or Buffered
- Registered, unbuffered
- Intel Extreme Memory Profiles (XMP), quad channel memory architecture
- Details
- 256 GB - registered , 128 GB - unbuffered
Audio
- Audio Codec
- Realtek ALC1150
- High Definition Audio
LAN
- Network Interfaces
- Expansion Slots
- 1 x CPU , 8 x DIMM 288-pin , 2 x PCIe 3.0 x16 , 2 x PCIe 3.0 x16 (x8 mode) , 1 x PCIe 2.0 x1 , 1 x M.2 socket
- Storage Interfaces
- SATA-600 -connectors: 6 x 7pin SATA, 1 x SATA Express port - RAID 0 / RAID 1 / RAID 10 / RAID 5 , PCIe 3.0 -connectors: 1 x M.2, 1 x U.2 , SATA-600 -connectors: 4 x 7pin Serial ATA - 4 devices
- 2 x LAN (Gigabit Ethernet) , 6 x USB 3.0 , 1 x audio line-out - mini-jack , 1 x audio line-in - mini-jack , 1 x microphone - mini-jack , 1 x audio line-out (rear) - mini-jack , 1 x audio line-out (center/subwoofer) - mini-jack , 1 x TOSLINK , 1 x PS/2 keyboard / mouse , 1 x USB 3.1 , 1 x USB-C
- Internal Interfaces
- 4 x USB 2.0 - header , 4 x USB 3.0 - header , 1 x audio - header , 1 x SPDIF out - header
- Power Connectors
- 24-pin main power connector, 8-pin ATX12V connector
- BIOS Type
- AMI
- BIOS Features
- WfM 2.0 support, UEFI BIOS, SMBIOS 2.7 support, DMI 2.7 support, ACPI 5.0 support, Dual BIOS
- Hardware Monitoring
- CPU core temperature, chassis temperature, CPU fan tachometer, chassis fan tachometer, system voltage, CPU overheating protection
- Hardware Features
- AutoGreen, NVIDIA 3-way SLI Technology Support, Intel Extreme Memory Profile (XMP) support, NVIDIA Quad SLI Technology Support, NVIDIA 2-way SLI Technology Support, On/Off Charge, Ultra Durable, AMD CrossFireX technology support, AMD Quad CrossFireX technology support, AMD 3-way CrossFireX technology support, ESD Protection, Easy RAID Installer, All IR digital power design, 2x Copper PCB, Q-Flash Plus, IR PowIRstage ICs, Cooper Bussmann Chokes, Durable Black Solid Caps, Turbo B-Clock, Ultra Durable PCIe Metal Shielding, Intel Turbo Boost Technology 3.0, RGB Ambient Surround LED, GIGABYTE Double Locking Bracket, Ultra Durable Memory Armor, Anti-Sulfur Design
- Software Included
- Norton Internet Security, @BIOS, EasyTune, Cloud Station, Xpress Install, GIGABYTE USB Blocker, GIGABYTE App Center, cFosSpeed, Smart TimeLock, GIGABYTE Fast Boot, GIGABYTE V-Tuner, GIGABYTE Smart Keyboard, GIGABYTE Smart Backup
- Plug and Play, ACPI 5.0
- 30.5 cm
- 24.4 cm
