Your basket is empty
Gigabyte Wireless Bluetooth Optical Mouse - Black
Quicklinx: 9PVPWS00 Mfr#: GM-M7700B
Type: Mouse
Wired / Wireless: Wireless
Colour: Noble black
Compatibility: PC
Cherry MX Switch Colour: [N/A]
18 in stock
£18.89 ex VAT
£22.66 inc VAT
Standard delivery Delivered within 3-5 working days
Bluetooth Version 2.1 +EDR Wireless Technology
Bluetooth® 2.1 +EDR wireless technology supports adaptive frequency hopping, and its 79 channels allow faster, more stable connection, and a satisfying working range up to 10 meters.
GIGABYTE Accurate Laser Tracking System
Equipped with GIGABYTE accurate laser tracking system, the mouse is so responsive and easy to control. When you are using the mouse, you will find it as smooth as it is engaging.
800/1600 On-the-fly DPI Adjustable
You may adjust DPI sensitivity anytime you want to by simply clicking DPI-adjusting button on the mouse.
Internet Backward & Forward buttons
The side buttons near your thumb are the internet backward & forward keys. Use these keys when browsing web pages, and feel the convenience brought by them!
Stylish Design and Comfortable Grip
M7700B stays true to one of GIGABYTE’s core concepts – ergonomic design. The mouse is designed exclusively for right-hand users. Rubber grip topped it off with the extraordinary hand-feeling, that is already more than satisfying to users.
Low-Power Indicator
When the battery is low, the low-power indicator would blink for 5 seconds, and then turn off.
Gigabyte M7700B - mouse - Bluetooth - noble black
Mouse
Wireless - Bluetooth
Noble black
6 cm x 10 cm x 3.7 cm
60 g
Movement Detection Technology
Laser
Movement Resolution
1600 dpi
Performance
Realtime sensitivity switching 800/1600 dpi
AAA type
Microsoft Windows 7, Microsoft Windows 98/ME/2000/XP/Vista
Mouse
6 cm
10 cm
3.7 cm
60 g
Noble black
Input Device
Wireless
Bluetooth
Max Operating Distance
Up to 10 m
Laser
Movement Resolution
1600 dpi
Performance
FCC, Laser Class 1
AAA type
Type: Mouse
Colour: Noble black
Compatibility: PC
Brand: Gigabyte
Price Range Ex VAT: 0 - 50
