Your basket is empty
Gigabyte S3000 2.0 USB Speakers White
Quicklinx: B345WS00 Mfr#: GP-S3000 WHT
Enjoy the pleasure of true gaming with S3000 speakers. The speakers project sound evenly in all direction, for you to enjoy clear sound from any angle throughout the room. You can enjoy sound with 150 Hz to 20,000 Hz frequency response and get big bass, perfect mids and smooth highs. Different from other USB-powered speakers, S3000 embeds individual audio codec presenting every gaming detail. With its audio codec, S3000 reflects distortion-free gaming effects of footstep, gun shooting, and team talk. The USB connectivity delivers both audio and power. It's that easy, just plug and play and get your true-to-life, loud and clear sound.
Gigabyte GP-S3000 - speakers - for PC
Speakers - PC multimedia
12.8 cm x 12 cm x 18.3 cm
1.1 kg
System Components
2 speakers
Speaker Type
Active
Nominal Output Power (Total)
4.5 Watt
Frequency Response
150 - 20000 Hz
Audio Amplifier
Integrated
Speaker System Details
2 x speaker 150 - 20000 Hz
White
Power Options
USB powered
Speakers - for PC
12.8 cm
12 cm
18.3 cm
1.1 kg
Enclosure Colour
White
Speaker System
System Components
2 speakers
Speaker Type
Active
4.5 Watt
Frequency Response
150 - 20000 Hz
Audio Amplifier
Integrated
Controls
Mute, power on/off, volume
Additional Features
Touch sensor buttons
Speakers Included
2 x speaker - 150 - 20000 Hz - wired
Driver Details
Speaker: 1 x full-range driver - 3"
Connector Type
USB 3.0 ( 9 pin USB Type A ) , Audio line-in ( mini-phone stereo 3.5 mm ) , Headphones ( mini-phone stereo 3.5 mm ) , Microphone ( mini-phone 3.5mm )
Power Source
USB
Options
USB powered
