Gigabyte Radeon RX 7700 XT 12G - OC Edition - Graphics Card
Quicklinx: HVH3WS00 Mfr#: GV-R77XTGAMING OC-12GD
Graphics Processor Manufacturer: AMD
Graphics Processor: AMD Radeon RX 7700 XT
Interface: PCI Express 4.0
£391.25 ex VAT
£469.50 inc VAT
The GIGABYTE Radeon RX 7700 XT GAMING OC 12G is designed to deliver exceptional gaming and creative performance. With 12 GB of GDDR6 SDRAM and a boost clock speed of 2599 MHz, it offers the speed and power to handle demanding games and applications with ease. The card supports DirectX 12 Ultimate and OpenGL 4.6, enabling advanced visual effects and gaming features for an immersive experience.
Its cooling system, featuring the GIGABYTE WINDFORCE design with triple 90 mm fans, graphene nano lubricant, and a copper base, ensures optimal performance by keeping temperatures low during intense gaming sessions. Additionally, the card's support for up to 4 monitors and high-resolution outputs up to 7680 x 4320 allows for a versatile setup, whether for gaming, content creation, or productivity tasks. With its robust build and performance-enhancing features, the GIGABYTE Radeon RX 7700 XT GAMING OC 12G is an excellent choice for gamers and creative professionals looking for a high-quality video card.
  • Enhanced cooling
    The GIGABYTE Radeon RX 7700 XT GAMING OC 12G features the GIGABYTE WINDFORCE cooling design, incorporating triple 90 mm fans, graphene nano lubricant, and a copper base to ensure your video card remains cool under pressure, enhancing performance and durability.
  • Superior visuals
    With a boost clock speed of 2599 MHz and 12 GB of GDDR6 SDRAM, this graphics card delivers stunning visuals and smooth gameplay. The support for DirectX 12 Ultimate and OpenGL 4.6 enables advanced gaming effects for an immersive gaming experience.
  • Advanced connectivity
    Equipped with 2 HDMI and 2 DisplayPort outputs, supporting up to 4 monitors and a maximum external resolution of 7680 x 4320, this video card offers versatile connectivity options for a multi-display setup or high-resolution gaming and content creation.
Gigabyte Radeon RX 7700 XT GAMING OC 12G - OC Edition - graphics card - Radeon RX 7700 XT - 12 GB
Graphics card
Bus Type
PCI Express 4.0
Graphics Engine
AMD Radeon RX 7700 XT - up to
12 GB GDDR6
Memory Speed
18 Gbps
Boost Clock
2599 MHz
Stream Processors
3456
Memory Interface
192-bit
Max Resolution
7680 x 4320
Max Monitors Supported
4
Interfaces Details
2 x HDMI , 2 x DisplayPort
API Supported
DirectX 12 Ultimate, OpenGL 4.6
5.6 cm x 30.2 cm x 13 cm
Graphics card
Bus Type
PCI Express 4.0
Graphics Engine
Boost Clock
2599 MHz
Stream Processors
3456
Max Resolution
7680 x 4320
4
Interfaces Details
API Supported
Triple Fan Design, RGB fusion, Dual Bios, GIGABYTE WINDFORCE cooling design, metal backplate, RDNA 3 Gaming Architecture, Triple 90mm Fan Design, copper base, Gigabyte Alternate Spinning, Graphene Nano Lubricant, Ultra Durable VGA, AMD Radeon Anti Lag Technology, AMD Noise Suppression, Radeon Image Sharpening, AMD Radeon Boost Technology, AMD FidelityFX Super Resolution (FSR), AMD Link
Size
12 GB
GDDR6 SDRAM
Memory Speed
18 Gbps
Bus Width
192-bit
Required Power Supply
700 W
Additional Requirements
2 x 8 pin PCI Express power connector
Software Included
Gigabyte Control Center
DisplayPort 2.1
5.6 cm
30.2 cm
13 cm
Brand: Gigabyte
