Gigabyte Radeon RX 7600 XT GAMING OC 16G Graphics Card
Quicklinx: HVH4WS00 Mfr#: GV-R76XTGAMING OC-16GD
Graphics Processor Manufacturer: AMD
Graphics Processor: AMD Radeon RX 7600 XT
Interface: PCI Express 4.0
20 In Stock
£281.51 ex VAT
£337.81 inc VAT
The GIGABYTE Radeon RX 7600 XT GAMING OC 16G video card is designed for gamers and creative professionals who demand high performance and reliability. With a robust 2810 MHz boost clock speed and 16 GB of GDDR6 memory, it delivers exceptional graphics and smooth, lag-free gameplay. The card's advanced cooling system, featuring the GIGABYTE WINDFORCE technology, ensures it stays cool under pressure, while its support for multiple monitors and high-resolution displays makes it versatile for any setup. Enhanced with AMD's technologies, including FidelityFX Super Resolution and Radeon Anti Lag, it offers a superior gaming experience. Its durable construction, including a metal backplate and innovative cooling features, ensures long-lasting performance, making it a smart investment for serious gamers and professionals alike.
  • Enhanced cooling
    The GIGABYTE Radeon RX 7600 XT GAMING OC 16G features the GIGABYTE WINDFORCE cooling design, incorporating a triple fan design, composite copper heat pipes, and Heat Pipe Direct Touch technology to efficiently dissipate heat, ensuring optimal performance even under heavy loads.
  • Superior visuals
    With support for DirectX 12 Ultimate and OpenGL 4.6, alongside the RDNA 3 Gaming Architecture and AMD FidelityFX Super Resolution (FSR), this video card delivers stunning visuals and smooth gameplay, enhancing your gaming and creative work.
  • Advanced connectivity
    Equipped with 2 DisplayPort and 2 HDMI ports, the video card supports up to 4 monitors, allowing for a versatile setup that can handle high-resolution displays up to 7680 x 4320, perfect for immersive gaming and productive multitasking.
  • Innovative features
    This model boasts a range of AMD technologies including AMD Noise Suppression, AMD Radeon Anti Lag Technology, and AMD Radeon Boost Technology, designed to improve your gaming experience by reducing noise, lag, and boosting performance where it counts.
  • Durable build
    The video card is built to last with a metal backplate, lower RDS MOSFETs, and Graphene Nano Lubricant, ensuring durability and reliability for years of high-performance usage.
Gigabyte Radeon RX 7600 XT GAMING OC 16G - graphics card - Radeon RX 7600 XT - 16 GB
Graphics card
Bus Type
PCI Express 4.0
Graphics Engine
AMD Radeon RX 7600 XT - up to
16 GB GDDR6
Memory Speed
18 Gbps
Boost Clock
2810 MHz
Stream Processors
2048
Memory Interface
128-bit
Max Resolution
7680 x 4320
Max Monitors Supported
4
Interfaces Details
2 x DisplayPort , 2 x HDMI
API Supported
DirectX 12 Ultimate, OpenGL 4.6
5.26 cm x 28.14 cm x 11.66 cm
Graphics card
Bus Type
PCI Express 4.0
Graphics Engine
Boost Clock
2810 MHz
Stream Processors
2048
Max Resolution
7680 x 4320
4
Interfaces Details
API Supported
Triple Fan Design, AV1 hardware encode, GIGABYTE WINDFORCE cooling design, metal backplate, RDNA 3 Gaming Architecture, RGB fusion, AMD FidelityFX Super Resolution (FSR), AMD Noise Suppression, AMD Radeon Anti Lag Technology, AMD Radeon Boost Technology, AMD Radiance Display Engine, AMD Smart Technologies, AMD Radeon Super Resolution (RSR), RT + AI accelerators, AMD HYPR-RX technologies, AMD Fluid Motion Frames, 3D Active Fan, 80mm Unique blade fan design, composite copper heat pipes, Gigabyte Alternate Spinning, Graphene Nano Lubricant, Heat Pipe Direct Touch technology, LED indicators, lower RDS MOSFETs, screen cooling, vented backplate
Size
16 GB
GDDR6 SDRAM
Memory Speed
18 Gbps
Bus Width
128-bit
Required Power Supply
600 W
Additional Requirements
Two 8-pin power connectors
Software Included
AMD Radeon Software Adrenalin Edition, Gigabyte Control Center
DisplayPort 2.1
5.26 cm
28.14 cm
11.66 cm
Brand: Gigabyte
