Main Features
- Premium Gaming Graphics NVIDIA® GeForce® GTX 970M GDDR5 3GB.
- 6th gen Intel® quad-core i7 processor.
- HDMI 2.0 with HDCP 2.2 supports 4K@60Hz output.
- USB 3.1 Type-C for high Speed transmission.
- M.2 PCIe SSD – Storage Speed in Overdrive.
- DDR4 – Data Storage’s Limit Breaker.
- Swappable bay for ODD / weight Saver / extendable storage.
- Optional ODD with Blu-ray Rewritable for Massive Data Backup.
- 30-keys Rollover Anti-ghost Backlit Keyboard.
- Hard-core gaming ID look.
GTX 970M Graphics: Unleash Your Gaming Soul
The P57W features a speedy NVIDIA® GeForce® GTX 970M graphics processor. A total package of 3GB VRAM handles higher frame refresh rate with ease and is capable of rendering more detailed graphics when running resource-demanding titles. Scoring P9100+ in 3DMARK 11, the P57W with NVIDIA® GeForce® GTX 970M gives you a solid edge over other competitors while gaming.
6th Gen Intel® Core™ i7 Processor: Better Performance Through and Through.
The new 6th Generation Intel® Core™ i7 processor features the Intel® Skylake architecture with 14nm process, giving you blazing speed and performance which will complete your computing experience. With this new boost in performance, you can do more on your laptop ranging from work to play. Together with PCIe SSD, DDR4 memory, USB 3.1 Type-C, and HDMI 2.0, Skylake allows you to start gaming right away!
DDR4 is breaking through the limits of data storage. Better than its predecessor DDR3 in every way, DDR4 is essential for any high-resolution game, or data-intensive application. It runs at a frequency of 2133 MHz, which allows games to run faster and smoother like never before! DDR4 also possesses more storage with a max capacity of 16GB per stick, double that of DDR3. Whether you are gaming or working, DDR4 will be able to provide superior performance!
Full HD IPS Wide View Display for Crisp & Rich Vision
The 1080p Full HD IPS wide viewing angle display realizes premium viewing experience plus astonishing color accuracy and crystal clear images when screen sharing. The Full HD matte display panel diffuses light and eliminates reflections, upgrading your viewing experience and creating the most realistic gaming experience.
HDMI 2.0: Higher Frame Rate, Higher Potential
The era of true 4K Ultra-HD is upon us! The untapped potential of 4K resolutions is realized through HDMI 2.0! Unlike HDMI 1.4 which only supports 8-bit color and 30 FPS, HDMI 2.0 can display games like never before! Supporting up to 18 Gbps transfer, the true potential of 4K resolution is realized through 12-bit color and 60Hz refresh rate! Finally see your favorite games how they were meant to be seen, in true high definition!
USB 3.1 Type-C: Upgraded Convenience
The frustrations of turning a USB over and over trying to get it to plug has ended. With the introduction of USB 3.1 Type-C universal connector, connecting a USB is no longer a fuss. Not only is it easier to plug, it also has twice the throughput of USB 3.0, transferring 100GB video in as little as 80 seconds. Being able to transfer data faster and possesses much improved pluggability greatly improves any user’s daily routine!
Anti-ghost Backlit Keyboard: Never Miss an Action
When too many keys on a traditional keyboard are pressed at once, you will experience "ghosting" that stops some keys from registering, which will cause an action to be executed incorrectly or at the wrong time. With P57 30-keys rollover keyboard, experience anti-ghosting with precise control of the keyboard no matter how many keys are held down at once. The backlit keyboard also allows gamers to play in the dark. Execute actions with ease and comfort.
Multi-Usages: Swappable ODD/HDD Slot
The ingenious design of the swappable ODD/HDD slot* brings more choices as well as opportunities for gamers. The swappable bay can take a DVD RW drive, Blu-ray drive or additional 2TB HDD. Ultimate customization creates unprecedented mobility.
XSplit Gamecaster + Broadcaster: Cast your Game Anytime, Anywhere
Live stream on a laptop has never been easier. Now set up your stage and share the greatest gaming moments with XSplit Gamecaster + Broadcaster! Fully optimized social media integration is ready for real-time chats—keeping you notified yet focused in the game. It takes just one click to stream your gameplay to Twitch. Now you can host your game like a pro! The show starts whenever you flip open your laptop.
Dolby Digital Plus™: Surround Sound Anywhere, Everywhere
Dolby Digital Plus™ creates a realistic game-play environment that lets you hear every window smash, feel every explosion, and experience every wipeout as if they're really happening. Surround Virtualizer creates a virtualized surround sound experience of stereo or multichannel content over built-in speakers or over headphones. Whether you're playing games, watching Blu-ray movies, or streaming videos, your P57 is an awesome multi-entertainment hub when it has advanced Dolby Digital Plus™.
Phenomenal Design: Lead the pack
The P57 features aerodynamic streamlines in quality matte black finish, creating an all new unique design element. It will definitely make you stand out from the crowd on the go or your next LAN party. Take on the competition with the beast.
Smart Dashboard Readies You for Any Challenge
The best policy to win any game is to make sure your system is 100% with you. Smart Dashboard presents the real-time monitor on your system information, including CPU & GPU loads, temperature, fan speed, network conditions and power scheme. A simple glance is all it takes to keep track of how your system works.
Fan Tweak: Customized Stability
Fan Tweak tailors your fan speed to different user scenarios, striking a perfect balance between system stability and needs for tranquility. Under "Customize" mode, you can adjust the fan speed of Normal mode and Gaming mode, embracing the great performance and quiet environment on your own. 4 modes offers for all-condition tweak options.
