Main Features
- NVIDIA® GeForce® GTX 970M 6GB.
- 6th Generation Intel® Core™ i7 Processor.
- Full HD IPS Display.
- M.2 PCIe SSD – Storage Speed in Overdrive.
- DDR4 – Data Storage’s Limit Breaker.
- USB 3.1 Type-C – Upgraded Convenience.
- HDMI 2.0 – Higher Frame Rate, Higher Potential.
- Huge 75.81Wh Battery Capacity for Continuous Gaming.
- Light & Slim: Only 2.8kg, 22.5mm.
- Unique Macro Hub for Gamers.
- Quad-storage with Swappable Bay.
- XSplit Gamecaster Streaming Software.
Stunning GTX 970M Graphics: Unleash Your Gaming Soul
P37W v5 features a NVIDIA® GeForce® GTX 970M GDDR5 6GB, capable of P9,000+ in 3DMark 11*, ensuring users a solid edge over the competition. Battery Boost 2.0 delivers an uncompromised gaming experience with 30% extra battery life at the same frame rate.
Larger VRAM for Victory
Running major titles at ultra-high resolution with 4X anti-aliasing and the finest details enabled, takes extra graphics memory. GIGABYTE P37 is packed with double VRAM capacity compared to the majority of our competitors, rendering stunning effects without compromising on system performance. Head straight for more FPS with lighting effect, motion blur, and texture filtering checked to high… Your P37 is fully loaded for the battle.
6th Gen Intel® Core™ i7 Processor—Better Performance Through and Through.
The new 6th Generation Intel® Core™ i7 processor features the Intel® Skylake architecture with 14nm process, giving you blazing speed and performance which will complete your computing experience. With this new boost in performance, you can do more on your laptop ranging from work to play. Together with PCIe SSD, DDR4 memory, USB 3.1 Type-C, and HDMI 2.0, Skylake allows you to start gaming right away!
DDR4 is breaking through the limits of data storage. Better than its predecessor DDR3 in every way, DDR4 is essential for any high-resolution game, or data-intensive application. It runs at a frequency of 2133 MHz, which allows games to run faster and smoother like never before! DDR4 also possesses more storage with a max capacity of 16GB per stick, double that of DDR3. Whether you are gaming or working, DDR4 will be able to provide superior performance!
The frustrations of turning a USB over and over trying to get it to plug has ended. With the introduction of USB 3.1 Type-C universal connector, connecting a USB is no longer a fuss. Not only is it easier to plug, it also has twice the throughput of USB 3.0, transferring 100GB video in as little as 80 seconds. Being able to transfer data faster and possesses much improved pluggability greatly improves any user’s daily routine!
The era of true 4K Ultra-HD is upon us! The untapped potential of 4K resolutions is realized through HDMI 2.0! Unlike HDMI 1.4 which only supports 8-bit color and 30 FPS, HDMI 2.0 can display games like never before! Supporting up to 18 Gbps transfer, the true potential of 4K resolution is realized through 12-bit color and 60Hz refresh rate! Finally see your favorite games how they were meant to be seen, in true high definition!
Full HD IPS Display with Wide Viewing Angle
The 1080p Full HD IPS display grants wide viewing angle, rendering vivid color and sensational impacts. Sharing game scenes with your partners will no longer be a problem.
Huge Battery Capacity for Continuous Gaming
Portability and battery life go hand-in-hand and are both essential for mobile gamers. With a slimline design that few gaming laptops achieve, the P37 takes it a step further by also providing a large capacity battery, up to 75.81Wh. That’s an additional 21% compared to other slim gaming laptops, generating up to 8 hours of usage. The P37’s large capacity battery provides uncompromised power for running any game or resource-demanding applications on the go.
Incredible Design
The mix of innovative thermal design as well as continual commitment to user experience generates this super slim and lightweight gadget—22.5mm / 2.8Kg. P37 v5 will surely reign the thinnest and lightest gaming laptop in its class.
Dolby Digital Plus™: Surround Sound Anywhere, Everywhere
Dolby Digital Plus™ creates a realistic game-play environment that lets you hear every window smash, feel every explosion, and experience every wipeout as if they're really happening. Surround Virtualizer creates a virtualized surround sound experience of stereo or multichannel content over built-in speakers or over headphones. Whether you're playing games, watching Blu-ray movies, or streaming videos, your P37 is an awesome multi-entertainment hub when it has advanced Dolby Digital Plus™.
Auto-adjust Backlit Keyboard
The P37 comes with an ambient-light sensing backlit keyboard. It adjusts the light emitted dependent on the user’s environment, making typing in dimly lit conditions and gaming in the dark free of troubles.
