P15F v5 features a speedy graphics processor. A total package of VRAM handles higher frame refresh rate with ease and is capable of rendering more detailed graphics when running resource-demanding titles. The powerful processor features the Skylake architecture with 14 nm process, giving you blazing speed and performance which will complete your computing experience. With this boost in performance, you can do more on your laptop ranging from work to play. Never worry about the battery life as this chip consumes less power. Sound Blaster Cinema 2 includes professionally-tuned profiles to deliver an exceptional and immersive audio experience. With SBX Surround, an improved surround algorithm increases and expands the virtual surround spaciousness, allowing you to enjoy cinema-quality sound even when on the move. Immerse yourself right in the middle of all the action. SBX Dialog Plus enhances the voices in movies for clearer dialog, allowing the listener to hear the dialog over the rest of the soundtrack and over ambient noise in the listening environment.
Gaming-class graphics - unleash your gaming souls
P15F v5 features a speedy graphics processor. A total package of VRAM handles higher frame refresh rate with ease and is capable of rendering more detailed graphics when running resource-demanding titles. -
Fast processor - better performance through and through
The powerful processor features the Skylake architecture with 14 nm process, giving you blazing speed and performance which will complete your computing experience. With this boost in performance, you can do more on your laptop ranging from work to play. Never worry about the battery life as this chip consumes less power. -
Relive your games with Sound Blaster Cinema 2
Sound Blaster Cinema 2 includes professionally-tuned profiles to deliver an exceptional and immersive audio experience. With SBX Surround, an improved surround algorithm increases and expands the virtual surround spaciousness, allowing you to enjoy cinema-quality sound even when on the move. Immerse yourself right in the middle of all the action. SBX Dialog Plus enhances the voices in movies for clearer dialog, allowing the listener to hear the dialog over the rest of the soundtrack and over ambient noise in the listening environment. -
Full HD IPS display for crisp & rich vision
The 1080p IPS display with great viewing angle realizes premium viewing experience plus startling color accuracy and clear images when screen sharing comes in need. -
Full-sized chiclet keyboard
The full-sized chiclet keyboard creates snappy yet responsive typing experience for long-hour operation. The independent numeric keyboard brings desktop experience to your laptop, improving typing experiences while eliminating mistypes. -
Unique design
The P15F v5 features angular diamond lines in quality matte finish, creating an unique design element. The outstanding design will definitely distinct you from the crowd either in any gatherings or your next LAN party.
- Gigabyte P15F v5 - 15.6" - Intel Core i7 - 6700HQ - 8 GB RAM - 128 GB SSD + 1 TB HDD
- Product Type
- Notebook
- Operating System
- Win 10 Home 64-bit
- Processor
- Intel Core i7 (6th Gen) - 6700HQ / 2.6 GHz, up to 3.5 GHz / 6 MB Cache
- Memory
- 8 GB DDR3L
- Storage
- 128 GB SSD + 1 TB HDD / 7200 rpm
- Optical Drive
- DVD-Writer
- Display
- 15.6" LED backlight 1920 x 1080 / Full HD - matte
- Graphics
- NVIDIA GeForce GTX 950M
- Video Memory
- 2 GB DDR3 SDRAM
- Numeric Keypad
- Integrated Webcam
- Networking
- 802.11b/g/n, Bluetooth 4.0, Gigabit Ethernet
- Battery
- 6-cell
- Matte black
- 37.4 cm x 25.2 cm x 3.14 cm
- 2.5 kg
- Environmental Standards
- - EPEAT Climate+
- Limited warranty - 2 years - pick-up and return
- Product Type
- Notebook
- Operating System
- Windows 10 Home 64-bit Edition
Processor / Chipset
- CPU
- Intel Core i7 (6th Gen) 6700HQ / 2.6 GHz
- Max Turbo Speed
- 3.5 GHz
- Number of Cores
- Quad-Core
- Cache
- 6 MB
- 64-bit Computing
- Chipset
- Mobile Intel HM170
- Intel Turbo Boost Technology 2.0
- RAM
- 8 GB
- Max RAM Supported
- 16 GB
- Technology
- DDR3L SDRAM
- Speed
- 1600 MHz
- Slots Qty
- 2
Storage
- Main Storage
- 128 GB SSD M.2 SATA
- Secondary Storage
- 1 TB HDD / 7200 rpm
- Optical Drive
- DVD-Writer
Display
- 15.6" - IPS
- LCD Backlight Technology
- LED backlight
- Resolution
- 1920 x 1080 (Full HD)
- Widescreen
- WideView, matte
Audio & Video
- Graphics Processor
- Video Memory
- 2 GB DDR3 SDRAM
- Camera
- Yes - HD
- Sound
- Stereo speakers, microphone
- SBX Surround audio, Sound Blaster Cinema 2
Input
- Keyboard, touchpad
- Numeric Keypad
Communications
- Wireless
- Network Interface
- Gigabit Ethernet
- Technology
- 6-cell Lithium Ion
- Capacity
- 48.84 Wh
Connections & Expansion
- Interfaces Details
- Headphone output , LAN , VGA , HDMI , USB 2.0 , 3 x USB 3.0 , Microphone input
- Memory Card Reader
- 9 in 1 (SD Card, Memory Stick, Memory Stick PRO, MultiMediaCard, Memory Stick Duo, RS-MMC, miniSD, SDHC Card, SDXC Card)
Software
- Software Included
- XSplit Gamecaster (3 months Premium licence)
- Matte black
- Security lock slot (cable lock sold separately), hot-swappable strorage bay
- Included Accessories
- Power adapter
- 2.5 kg
Sustainability Information
- TCO Certified
- EPEAT Compliant
- EPEAT Climate+
