Gigabyte Nvidia GTX 1080 Turbo OC 8GB GDDR5 PCI-E
Quicklinx: CQR1WS00 Mfr#: GV-N1080TTOC-8GD
GIGABYTE Turbo Fan Cooling System features the exclusive blower fan design with the heat pipe direct touch technology to efficiently direct the heat out of the case, delivering blazing fast yet stable performance when running VR or games in ultra HD. The card is also easy to install within the 2 PCI-E slot width due to its compact profile. The composite heat-pipes combine both thermal conductivity and phase transition for efficiently managing the transfer of heat between two solid interfaces which cooling capacity.
  • Turbo Fan Cooling System
  • Composite heat-pipes
  • Heat Pipe Direct Touch technology
    The pure copper heat pipes are shaped to maximize the direct contact area to the GPU.
  • One-click super overclocking
    With a simple click on XTREME engine utility, gamers can easily tune the card to meet their various gaming requirements without any overclocking knowledge, while saving the hassle of manual adjustment.
  • Ultra-durable materials
    Engineered with the high-quality chokes and capacitors, this graphic card delivers outstanding performance and durable system lifespan.
  • Built for overclocking with 8+2 power phases
    The 8+2 power phases on the card make the MOSFET working at a lower temperature and provide more stable voltage output.
  • XTREME Engine
    Clock speeds, voltage, fan performance, power target can be monitored and tuned in real-time according to your own preference through this intuitive interface.
Gigabyte GeForce GTX 1080 Turbo OC 8G - graphics card - GF GTX 1080 - 8 GB
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
NVIDIA GeForce GTX 1080
8 GB GDDR5X
Core Clock
1657 MHz
Boost Clock
1797 MHz
Effective Memory Clock
10.01 GHz
Memory Interface
256-bit
Max Resolution
7680 x 4320
Max Resolution Details
DisplayPort: 7680 x 4320 at 60 Hz/ HDMI: 4096 x 2160 at 60 Hz
Max Monitors Supported
4
DVI-D (dual link) , 3 x DisplayPort , HDMI
API Supported
DirectX 12, OpenGL 4.5
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
Core Clock
1657 MHz
Boost Clock
1797 MHz
Process Technology
16 nm
VR Ready
Max Resolution
4
API Supported
Ultra Durable VGA, NVIDIA G-Sync ready, NVIDIA GameWorks, Heat Pipe Direct Touch technology, 8+2 Phase PWM Design, Nvidia GeForce GTX VR Ready, GIGABYTE Turbo Fan Cooling System
Size
8 GB
GDDR5X SDRAM
Effective Clock Speed
10.01 GHz
Bus Width
256-bit
Required Power Supply
500 W
Additional Requirements
8 pin PCI Express power connector
Software Included
GeForce Experience, XTREME Engine Utility
