GeForceĀ® GTX 1060 Mini ITX OC 3G
Powered by GeForceĀ® GTX 1060
Integrated with 3GB GDDR5 192bit memory
90mm cooler with 3D active fan
One-click Super Overclocking
17cm Compact Card Size
Core Clock
Boost: 1771MHz/ Base: 1556 MHz in OC Mode
Boost: 1746 MHz/ Base: 1531 MHz in Gaming Mode
Custom-designed cooling system
Equipped with 2 pure copper heat-pipes and 90 mm unique-blade fan with 3D active functionality, and heat pipes direct touch technology, the cooler can dissipate heat effectively from the GPU while keeping the fan at lower speed and noise. -
Unique blade fan design
The airflow is spilled by the triangle fan edge, and guided smoothly through the 3D stripe curve on the fan surface, effectively enhancing the air flow by 23% over traditional fans. -
3D active fan
The semi-passive fans will remain off when the GPU is under a set loading or temperature for low power gaming. It allows gamers to enjoy gameplay in complete silence when the system is running light or idle. -
Composite heat-pipes
The composite heat-pipes combines both thermal conductivity and phase transition for efficiently managing the transfer of heat between two solid interfaces which increases 29% of cooling capacity. -
Heat pipe direct touch
The pure copper heat pipes are shaped to maximize the direct contact area to the GPU. -
Compact card size
Measuring merely 17 cm in length, the card, perfectly compatible for building most of the PCs from ATX to mini-ITX.
- Gigabyte GeForce GTX 1060 Mini ITX OC 3G - graphics card - GF GTX 1060 - 3 GB
- Graphics card
- Bus Type
- PCI Express 3.0 x16
- Graphics Engine
- NVIDIA GeForce GTX 1060
- Memory
- 3 GB GDDR5
- Core Clock
- 1556 MHz
- Boost Clock
- 1771 MHz
- Effective Memory Clock
- 8.008 GHz
- Memory Interface
- 192-bit
- Max Resolution
- 7680 x 4320
- Max Monitors Supported
- 4
- Interfaces Details
- 2 x DVI-D , DisplayPort , HDMI
- API Supported
- DirectX 12, OpenGL 4.5
- 17 cm
- Graphics card
- Bus Type
- Graphics Engine
- Core Clock
- 1556 MHz
- Boost Clock
- 1771 MHz
- Process Technology
- 16 nm
- VR Ready
- Max Resolution
- 7680 x 4320
- 4
- API Supported
- Ultra Durable VGA, NVIDIA G-Sync ready, NVIDIA GameWorks, Heat Pipe Direct Touch technology, Nvidia GeForce GTX VR Ready, 90mm Unique blade fan design
- Size
- 3 GB
- Technology
- GDDR5 SDRAM
- Effective Clock Speed
- 8.008 GHz
- Bus Width
- 192-bit
- Software Included
- XTREME Engine Utility
- 17 cm
