Gigabyte NVIDIA GeForce GTX 1060 G1 GAMING 3GB GDDR5 WF2 PCIe3.0
Quicklinx: CB86WS00 Mfr#: GV-N1060G1 GAMING-3GD
  • DisplayPort
  • High-Definition Multimedia Interface (HDMI)
GeForceĀ® GTX 1060 G1 Gaming 3G
Powered by GeForceĀ® GTX 1060
Integrated with 3GB GDDR5 192bit memory
WINDFORCE 2X with Blade Fan Design
Support up to 8K display @60Hz
16.8M Customizable Color RGB Lighting
Core Clock
Boost: 1847 MHz/ Base: 1620 MHz in OC Mode
Boost: 1809 MHz/ Base: 1594 MHz in Gaming
  • WindForce 2x cooling system
    The WindForce 2x cooling system features two unique blade fans, 2 pure copper composite heat pipes, alternate spinning fan design, and heat pipes direct touch technology, together delivering an effective heat dissipation capacity for higher performance at lower temperatures.
  • Alternate spinning fan design
    Optimize air flow by the alternate spinning fans, that reduce air turbulence and effectively dissipate the heat.
  • Unique blade fan design
    The airflow is spilled by the triangle fan edge, and guided smoothly through the 3D stripe curve on the fan surface, effectively enhancing the air flow.
  • 3D active fan with LED indicators
    The semi-passive fans will remain off, when the GPU is under a set loading or temperature for low power gaming. The LED fan indicator on the top of the graphics card provides an instant display of the fan status.
  • Composite heat pipes
    The composite heat pipes combine both thermal conductivity and phase transition for efficiently managing the transfer of heat between two solid interfaces which increases cooling capacity.
  • Heat pipe direct touch
    The pure copper heat pipes are shaped to maximize the direct contact area to the GPU.
  • Stylish metal back plate
    The metal back plate offers rigidity and protection to the structure, while adding a sleek, clean look to the product.
  • Improved GPU
    Forged with the powerful GPU, the Gigabyte G1 graphics cards deliver higher overclocking capability in terms of excellent power switching, ensuring the high performance without compromising system reliability.
  • Smart power LED indicators
    Be alert, when PCI-E voltage is unstable with the smart power LED indicator.
  • Ultra-durable materials
    Engineered with the high-grade chokes and capacitors, this graphic card delivers outstanding performance and durable system lifespan.
  • Built for overclocking with 6+1 power phases
    The 6+1 power phases on the card make the MOSFET working at a lower temperature and provide more stable voltage output.
Gigabyte GeForce GTX 1060 G1 Gaming 3G (rev. 1.0) - OC Edition - graphics card - GF GTX 1060 - 3 GB
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
3 GB GDDR5
Core Clock
1620 MHz
Boost Clock
1847 MHz
Effective Memory Clock
8.008 GHz
Memory Interface
192-bit
Max Resolution
7680 x 4320
Max Monitors Supported
4
Interfaces Details
DVI-D (dual link) , 3 x DisplayPort , HDMI
API Supported
DirectX 12, OpenGL 4.5
4 cm x 27.8 cm x 11.4 cm
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
Core Clock
1620 MHz
Boost Clock
1847 MHz
Process Technology
16 nm
VR Ready
Max Resolution
7680 x 4320 at 60 Hz
4
Interfaces Details
API Supported
Ultra Durable VGA, LED indicator, GIGABYTE GPU Gauntlet Sorting, GIGABYTE WindForce 2x, 6+1 Phase Power System, NVIDIA G-Sync ready, NVIDIA GameWorks, Heat Pipe Direct Touch technology, Nvidia GeForce GTX VR Ready
Size
3 GB
GDDR5 SDRAM
Effective Clock Speed
8.008 GHz
Bus Width
192-bit
Required Power Supply
400 W
Additional Requirements
8 pin PCI Express power connector
Software Included
XTREME Engine Utility
4 cm
27.8 cm
11.4 cm
