GeForceĀ® GTX 1060 G1 Gaming 3G
Powered by GeForceĀ® GTX 1060
Integrated with 3GB GDDR5 192bit memory
WINDFORCE 2X with Blade Fan Design
Support up to 8K display @60Hz
16.8M Customizable Color RGB Lighting
Core Clock
Boost: 1847 MHz/ Base: 1620 MHz in OC Mode
Boost: 1809 MHz/ Base: 1594 MHz in Gaming
WindForce 2x cooling system
The WindForce 2x cooling system features two unique blade fans, 2 pure copper composite heat pipes, alternate spinning fan design, and heat pipes direct touch technology, together delivering an effective heat dissipation capacity for higher performance at lower temperatures. -
Alternate spinning fan design
Optimize air flow by the alternate spinning fans, that reduce air turbulence and effectively dissipate the heat. -
Unique blade fan design
The airflow is spilled by the triangle fan edge, and guided smoothly through the 3D stripe curve on the fan surface, effectively enhancing the air flow. -
3D active fan with LED indicators
The semi-passive fans will remain off, when the GPU is under a set loading or temperature for low power gaming. The LED fan indicator on the top of the graphics card provides an instant display of the fan status. -
Composite heat pipes
The composite heat pipes combine both thermal conductivity and phase transition for efficiently managing the transfer of heat between two solid interfaces which increases cooling capacity. -
Heat pipe direct touch
The pure copper heat pipes are shaped to maximize the direct contact area to the GPU. -
Stylish metal back plate
The metal back plate offers rigidity and protection to the structure, while adding a sleek, clean look to the product. -
Improved GPU
Forged with the powerful GPU, the Gigabyte G1 graphics cards deliver higher overclocking capability in terms of excellent power switching, ensuring the high performance without compromising system reliability. -
Smart power LED indicators
Be alert, when PCI-E voltage is unstable with the smart power LED indicator. -
Ultra-durable materials
Engineered with the high-grade chokes and capacitors, this graphic card delivers outstanding performance and durable system lifespan. -
Built for overclocking with 6+1 power phases
The 6+1 power phases on the card make the MOSFET working at a lower temperature and provide more stable voltage output.
- Gigabyte GeForce GTX 1060 G1 Gaming 3G (rev. 1.0) - OC Edition - graphics card - GF GTX 1060 - 3 GB
- Graphics card
- Bus Type
- PCI Express 3.0 x16
- Graphics Engine
- NVIDIA GeForce GTX 1060
- Memory
- 3 GB GDDR5
- Core Clock
- 1620 MHz
- Boost Clock
- 1847 MHz
- Effective Memory Clock
- 8.008 GHz
- Memory Interface
- 192-bit
- Max Resolution
- 7680 x 4320
- Max Monitors Supported
- 4
- Interfaces Details
- DVI-D (dual link) , 3 x DisplayPort , HDMI
- API Supported
- DirectX 12, OpenGL 4.5
- 4 cm x 27.8 cm x 11.4 cm
- Graphics card
- Bus Type
- Graphics Engine
- Core Clock
- 1620 MHz
- Boost Clock
- 1847 MHz
- Process Technology
- 16 nm
- VR Ready
- Max Resolution
- 7680 x 4320 at 60 Hz
- 4
- API Supported
- Ultra Durable VGA, LED indicator, GIGABYTE GPU Gauntlet Sorting, GIGABYTE WindForce 2x, 6+1 Phase Power System, NVIDIA G-Sync ready, NVIDIA GameWorks, Heat Pipe Direct Touch technology, Nvidia GeForce GTX VR Ready
- Size
- 3 GB
- Technology
- GDDR5 SDRAM
- Effective Clock Speed
- 8.008 GHz
- Bus Width
- 192-bit
- Required Power Supply
- 400 W
- Additional Requirements
- 8 pin PCI Express power connector
- Software Included
- XTREME Engine Utility
- 4 cm
- 27.8 cm
- 11.4 cm
