Gigabyte M7580 Wireless Mouse
Quicklinx: 9R1DWS00 Mfr#: M7580
Equipped with GIGABYTE precise optical tracking system and reliable 2.4GHz wireless transmission technology, the mouse is so responsive and easy to control. You'll find it hard to resist the charm!
  • GIGABYTE precise optical tracking system
  • 500/ 1000 on-the-fly DPI adjustable
  • Portable nano receiver
  • Stylish design and comfortable grip
  • 500/1000 DPI switch
    Pressing twin buttons together for three seconds, easily to switch 500 and 1000 resolution.
  • Ambidextrous design
    Balance outlook design, right and left hands can both control more conveniently.
  • Optical sensor
    Professional tracking stability.
    The nano receiver is so tiny that you can keep plugging it into your notebook even when you are on the move.
  • Reliable 2.4GHz wireless transmission
    2.4GHz wireless technology provides 10m effective working distance. Let your work more efficient.
Gigabyte M7580 - mouse - 2.4 GHz
Mouse
Wireless - 2.4 GHz
60 g
Wireless Receiver
USB wireless receiver
Movement Detection Technology
Optical
Movement Resolution
1000 dpi
Right and left-handed, switchable resolution
AAA type
Microsoft Certification
Compatible with Windows 7
Mouse
Wireless Receiver
60 g
Input Device
Wireless
2.4 GHz
Max Operating Distance
Up to 10 m
Optical
Movement Resolution
1000 dpi
1 x USB - 4 pin USB Type A
AAA type
