The GIGABYTE N3150N Mini-ITX motherboard is a fully integrated PC motherboard featuring powerful processor. Designed for compact, small form factor PC systems and devices, the GIGABYTE N3150N-D3V is entirely fanless, making it ideal for always-on, mission critical systems, as well as noise-sensitive digital entertainment systems.
High quality audio capacitors
GIGABYTE Ultra Durable motherboards use high quality Nippon Chemicon ARE series audio capacitors. These professional audio capacitors deliver a high quality sound resolution and sound expansion to create realistic sound effects for user experience. -
GIGABYTE Ultra Durable debuts on GIGABYTE motherboards, with a range of features and component choices that provide record-breaking performance, cool and efficient operation and extended motherboard lifespan. -
Ultra performance
GIGABYTE uses all solid caps and low RDS (on) MOSFETs which are rated to work at higher temperatures to provide a longer lifespan. -
Humidity protection
Humidity can play havoc on a motherboard's circuitry. GIGABYTE's Glass Fabric PCB design helps protect against electrical shorts due to humidity by reducing the gaps in spacing between PCB filaments. -
Power surge protection
GIGABYTE also uses anti-surge ICs to protect the motherboard against power surges.
- Gigabyte GA-N3150N-D3V - 1.0 - motherboard - mini ITX - Intel Celeron N3150
- Product Type
- Motherboard - mini ITX
- Processor
- Intel Celeron N3150 / 1.6 GHz (Quad-Core)
- Max RAM Size
- 8 GB
- RAM Supported
- 2 SO-DIMM slots - DDR3, DDR3L, non-ECC, unbuffered
- Storage Ports
- 4 x SATA-600
- USB / FireWire Ports
- 2 x USB 3.0 + 2 x USB 2.0 + (2 x USB 3.0 + 4 x USB 2.0 via headers)
- Graphics
- Intel HD Graphics
- Max Allocated RAM Size
- 512 MB
- Audio
- HD Audio (8-channel)
- LAN
- 2 x Gigabit Ethernet
- Product Type
- Processor
- Cache Memory
- 2 MB
Supported RAM
- Max Size
- 8 GB
- Technology
- DDR3, DDR3L
- Bus Clock
- 1600 MHz, 1333 MHz
- Supported RAM Integrity Check
- Non-ECC
- Registered or Buffered
- Unbuffered
- Dual channel memory architecture
Graphics
- Graphics Controller
- Intel HD Graphics
- 512 MB
Audio
- Audio Codec
- Realtek ALC887
- High Definition Audio
LAN
- Network Interfaces
- Expansion Slots
- 2 x SO-DIMM 204-pin , 1 x PCI , 1 x M.2 socket
- Storage Interfaces
- SATA-600 -connectors: 2 x 7pin Serial ATA - 2 devices , ASMedia ASM1061: SATA-600 -connectors: 2 x 7pin Serial ATA - 2 devices
- 1 x VGA , 1 x DVI-D , 2 x LAN (Gigabit Ethernet) , 2 x USB 2.0 , 2 x USB 3.0 , 1 x microphone - mini-jack , 1 x audio line-out - mini-jack , 1 x audio line-in - mini-jack , 1 x PS/2 keyboard , 1 x PS/2 mouse , 2 x serial
- Internal Interfaces
- 4 x USB 2.0 - header , 1 x audio - header , 2 x USB 3.0 - header , 1 x parallel - header
- Power Connectors
- 4-pin ATX12V connector, 24-pin main power connector
- BIOS Type
- AMI
- BIOS Features
- WfM 2.0 support, UEFI BIOS, SMBIOS 2.7 support, DMI 2.7 support, ACPI 5.0 support
- Hardware Monitoring
- CPU core temperature, chassis temperature, CPU fan tachometer, chassis fan tachometer, system voltage, CPU overheating protection, CPU core voltage
- Hardware Features
- All-Solid Capacitor motherboard Design, Ultra Durable, ESD Protection
- Software Included
- Norton Internet Security, @BIOS, Xpress Install, GIGABYTE App Center
- Plug and Play
- 17 cm
- 17 cm
