Product
Brand
Gigabyte H97M-D3H S1150 H97 4xDDR3 4xUSB3.0 10xUSB2.0 GBE mATX
Quicklinx: 9FX3WS00 Mfr#: GA-H97M-D3H
GA-H97M-D3H Intel® H97 Chipset
  • Supports 4th and 5th Generation Intel® Core™ processors
  • Extreme multi graphics support
  • HD Audio support
  • Highly efficient MOSFET design
  • LAN with high ESD Protection
  • GIGABYTE LAN Optimizer
  • Long lifespan Durable Solid caps
  • APP Center including EasyTune™ and Cloud Station™ utilities
  • GIGABYTE UEFI DualBIOS™
  • Intel® Small Business Advantage
Gigabyte GA-H97M-D3H - 1.0 - motherboard - micro ATX - LGA1150 Socket - H97
Motherboard - micro ATX
Chipset Type
Intel H97 Express
Processor Socket
1 x LGA1150 Socket
Compatible Processors
Pentium, Celeron, Core i5, Core i3, Core i7
Max RAM Size
32 GB
RAM Supported
4 DIMM slots - DDR3 , non-ECC
Storage Ports
6 x SATA-600 (RAID)
USB / FireWire Ports
4 x USB 3.0 + 2 x USB 2.0 + ( 2 x USB 3.0 + 6 x USB 2.0 via headers )
Max Allocated RAM Size
512 MB
Audio
HD Audio (8-channel)
LAN
Gigabit Ethernet
Chipset Type
Intel H97 Express
Processor Socket
LGA1150 Socket
Max Processors Qty
1
Supported RAM
Max Size
32 GB
DDR3
Bus Clock
1600 MHz, 1333 MHz
Supported RAM Integrity Check
Non-ECC
Dual channel memory architecture, Intel Extreme Memory Profiles (XMP)
Graphics
512 MB
Audio
Audio Codec
Realtek ALC892
High Definition Audio
LAN
Network Interfaces
Gigabit Ethernet
Expansion Slot(s)
4 x DIMM 240-pin , 1 x CPU , 1 x PCIe 3.0 x16 , 1 x PCIe 2.0 x16 ( x4 mode ) , 2 x PCI
Storage Interfaces
SATA-600 - connector(s): 6 x 7pin Serial ATA - 6 Device(s) - RAID 0 / RAID 1 / RAID 10 / RAID 5
RAID Features
Intel Smart Response Technology
1 x VGA , 1 x HDMI , 1 x DVI-D , 4 x USB 3.0 , 1 x LAN (Gigabit Ethernet) , 2 x USB 2.0 , 1 x PS/2 keyboard / mouse , 1 x audio line-out - mini-jack , 1 x audio line-in - mini-jack , 1 x microphone - mini-jack , 1 x audio line-out (center/subwoofer) - mini-jack , 1 x audio line-out (rear) - mini-jack , 1 x audio line-out (side surround) - mini-jack
Internal Interfaces
6 x USB 2.0 - header , 2 x USB 3.0 - header , 1 x audio - header , 1 x serial - header , 1 x parallel - header , 1 x SPDIF out - header
Power Connectors
24-pin main power connector, 8-pin ATX12V connector
BIOS Type
AMI
BIOS Features
WfM 2.0 support, UEFI BIOS, SMBIOS 2.7 support, DMI 2.7 support, ACPI 5.0 support
Hardware Monitoring
CPU core temperature, chassis temperature, CPU fan tachometer, chassis fan tachometer, system voltage, CPU overheating protection, CPU core voltage
Hardware Features
DualBIOS, Q-Flash, All-Solid Capacitor motherboard Design, Intel Extreme Memory Profile (XMP) support, On/Off Charge, Intel Smart Response Technology, Ultra Durable, AMD CrossFireX technology support, Intel Rapid Start Technology, Intel Smart Connect Technology, GIGABYTE LAN Optimizer, Intel Small Business Advantage support, ESD Protection, Clear CMOS Button, GIGABYTE Smart Switch
Software Included
Norton Internet Security, @BIOS, EasyTune, Cloud Station, GIGABYTE EZ Setup, Xpress Install, GIGABYTE USB Blocker, GIGABYTE App Center, Smart TimeLock, GIGABYTE Fast Boot
Plug and Play, ACPI 5.0
24.4 cm
22.5 cm
