The Xtreme Gaming series graphics cards are crafted for perfection in pursuit of amazing graphics experience for gaming enthusiasts. Based on an incredibly advanced architecture, Xtreme gaming graphics card bring you excellent gaming experience.
Advanced cooling system
The cooling system features a special fan design, double ball bearing structure, angular fin design and composite heat pipes, together delivering an effective heat dissipation capacity for higher performance at lower temperatures. -
Stack fan design
The stack fans provide larger and smoother airflow. And with more heatsink coverage, these stack fans will have better cooling performance. -
Special fan design
The airflow is split by the triangle fan edge, and guided smoothly through the 3D stripe curve on the fan surface, effectively enhancing the airflow. -
Double ball bearing structure
The double ball bearing structure has better heat endurance and efficiency than sleeve structure. Hence it will provide longer life time. -
Composite heat pipes
The composite heat pipes combine both thermal conductivity and phase transition for efficiently managing the transfer of heat between two solid interfaces which increases the cooling capacity. -
Large copper base plate
With direct contact to the GPU and VRAM, the large copper base plate combines the composite heat pipes to efficiently transfer heat generated from the interior cores to the heat sink, keeping the graphics card cool and stable for better performance.
- Gigabyte GeForce GTX 1080 Xtreme Gaming - Premium Pack - graphics card - GF GTX 1080 - 8 GB
- Graphics card
- Bus Type
- PCI Express 3.0 x16
- Graphics Engine
- NVIDIA GeForce GTX 1080
- Memory
- 8 GB GDDR5X
- Core Clock
- 1759 MHz
- Boost Clock
- 1784 MHz
- Effective Memory Clock
- 10.416 GHz
- Memory Interface
- 256-bit
- Max Resolution
- 7680 x 4320
- Max Monitors Supported
- 4
- Interfaces Details
- DVI-D (dual link) , 3 x DisplayPort , HDMI
- API Supported
- DirectX 12, OpenGL 4.5
- 5.6 cm x 28.9 cm x 13.8 cm
- 4 years warranty
- Graphics card
- Bus Type
- Graphics Engine
- Core Clock
- 1759 MHz
- Boost Clock
- 1784 MHz
- Process Technology
- 16 nm
- VR Ready
- Max Resolution
- 7680 x 4320 at 60 Hz
- 4
- API Supported
- Ultra Durable VGA, LED indicator, GIGABYTE WindForce 3x, Three Fans Cooler, Dual ball Bearing Fan, NVIDIA G-Sync ready, NVIDIA GameWorks, 0dB semi-passive fans, Nvidia GeForce GTX VR Ready
- Size
- 8 GB
- Technology
- GDDR5X SDRAM
- Effective Clock Speed
- 10.416 GHz
- Bus Width
- 256-bit
- Required Power Supply
- 500 W
- Additional Requirements
- 2 x 8 pin PCI Express power connector
- Included Accessories
- Dual 6-pin PCIe to 8-pin power cable, Xtreme gaming sticker, wrist protector, paper folder, XMP300 mouse pad, Xtreme VR Link extended bracket, Xtreme VR Link extended 5.25" front panel
- Cables Included
- 1 x SLI bridge
- 5.6 cm
- 28.9 cm
- 13.8 cm
- Limited warranty - 4 Years
