Gigabyte GPU NV 5080 WINDFORCE SFF 16G Fan
Quicklinx: J522WS00 Mfr#: GV-N5080WF3OC-16GD
Graphics Processor Manufacturer: NVIDIA
Graphics Processor: NVIDIA GeForce RTX 5080
Interface: PCI Express 5.0
Memory Size: 16GB
Digital Output: DisplayPort, High-Definition Multimedia Interface (HDMI)
  • High-Definition Multimedia Interface (HDMI)
  • DisplayPort
Hurry, only 2 left in stock!
£1,065.84 ex VAT
£1,279.00 inc VAT
Express delivery Order within the next 16 hours for delivery tomorrow
The GIGABYTE GeForce RTX 5080 WINDFORCE OC SFF 16G is built to deliver gaming and creative performance with its advanced features. Designed with 16 GB of GDDR7 SDRAM and a 256-bit bus width, this graphics card is capable of breathtaking visuals and exceptional speed, reaching memory speeds of 32 Gbps. With support for a maximum external resolution of 7680 x 4320 and the ability to connect up to four monitors, this card provides an immersive experience for gamers and creators alike.
The innovative GIGABYTE WINDFORCE cooling design ensures effective thermal management with a triple fan setup, vapor chamber technology, and features like 3D Active Fan. Additionally, this graphics card is equipped with NVIDIA G-Sync compatibility, NVIDIA DLSS 4, and advanced ray tracing capabilities, all contributing to a seamless visual experience. The inclusion of various video output options, such as HDMI and three DisplayPorts, makes it versatile for multiple setups, while the dual BIOS feature adds an extra layer of reliability for any user.
Gigabyte GeForce RTX 5080 WINDFORCE OC SFF 16G - graphics card - GeForce RTX 5080 - 16 GB
Graphics card
Bus Type
PCI Express 5.0
Graphics Engine
16 GB GDDR7
Memory Speed
32 Gbps
Memory Interface
256-bit
Max Resolution
7680 x 4320
Max Monitors Supported
4
Interfaces Details
3 x DisplayPort , HDMI
API Supported
OpenGL 4.6
5 cm x 30.4 cm x 12.6 cm
3-year warranty
Graphics card
Bus Type
PCI Express 5.0
Graphics Engine
Max Resolution
7680 x 4320
4
Interfaces Details
API Supported
OpenGL 4.6
GIGABYTE WINDFORCE cooling design, Triple Fan Design, Dual Bios, NVIDIA GeForce SFF-Ready, NVIDIA Blackwell GPU architecture, NVIDIA Reflex 2, NVIDIA DLSS 4, Nvidia Studio, Nvidia Broadcast, 4th gen Ray Tracing Cores, 5th gen Tensor Cores, NVIDIA G-Sync ready, 9th Gen NVIDIA Encoder, 3D Active Fan, Gigabyte Alternate Spinning, Vapor chamber cooling technology
Size
16 GB
GDDR7 SDRAM
Memory Speed
32 Gbps
Bus Width
256-bit
Required Power Supply
850 W
Additional Requirements
16 pin PCI Express power connector
3 x 8 pin to 12VHPWR cable, graphics card holder
DisplayPort 2.1a
5 cm
30.4 cm
12.6 cm
Limited warranty - 3 years
Memory Size: 16GB
Digital Output: High-Definition Multimedia Interface (HDMI)
Brand: Gigabyte
Price Range Ex VAT: £1000 - £1500
Stock Status: While stocks last
Stock Status: Clearance
