Gigabyte GM-M6800 Dual Lens Gaming Mouse - optical - 5 button - USB
Quicklinx: 88RVWS00 Mfr#: GM-M6800
Recommended Use: Gaming
Type: Mouse
Wired / Wireless: Wired
Colour: Noble black
Compatibility: PC
£8.25 ex VAT
£9.90 inc VAT
By using this gaming mouse, GM-M6800, you can adjust 2-level DPI by clicking the quick switch button to behave in variety conditions.
To make sure Gigabyte can provide better performance, Gigabyte has adopted Dual-lens optical technology to Gigabyte's product line. With this technology, mouse can achieve higher intensity light without disperse for advanced precision. You can work on photo paper, coating, painting papers, even on glass boards!
Want to surfing the web? GM-M6800 will be your best partner. Simply click on its hot keys will allow you to surfing back and forward easily on web. Too tired to use computer after work? GM-M6800 is designed ergonomically. Feeling comfortable by using this mouse no matter how long you play with it. No matter playing games or web surfing, GM-M6800 will definitely be your best choice.
Dual Lens technology features advanced precision
800/ 1600 DPI on-the-fly adjustable
Ergonomic shape with comfortable rubber grips
Ultra-smooth Teflon feet pads
Gigabyte GM-M6800 - mouse - USB - noble black
Mouse
Wired - USB
Noble black
7.5 cm x 12.7 cm x 4.3 cm
126 g
Movement Detection Technology
Optical
Buttons Qty
5
Movement Resolution
1600 dpi
Performance
3000 fps
Dual lens
1 x USB cable - integrated - 1.5 m
Microsoft Windows 98/ME/2000/XP, Microsoft Windows Vista
Mouse
7.5 cm
12.7 cm
4.3 cm
126 g
Noble black
Input Device
Wired
USB
Optical
Buttons Qty
5
Movement Resolution
1600 dpi
Performance
3000 fps
Dual lens
1 x USB - 4 pin USB Type A
BSMI, FCC
Type: Mouse
Colour: Noble black
Compatibility: PC
Brand: Gigabyte
Price Range Ex VAT: 0 - 50
