Gigabyte GF GV-N105TOC-4GL PCIE 3 LP
Quicklinx: CVDTWS00 Mfr#: GV-N105TOC-4GL
Graphics Processor Manufacturer: NVIDIA
Graphics Processor: NVIDIA GeForce GTX 1050 Ti, NVIDIA GeForce GTX 1050 Ti, NVIDIA GeForce GTX 1050 Ti
Interface: PCI Express 3.0 x16
Memory Size: 4GB, 4GB
£106.54 ex VAT
£127.84 inc VAT
The WindForce 2x cooling system features two unique blade fans and semi-passive 3D active fan together delivering an effective heat dissipation capacity for higher performance at lower temperatures. The airflow is spilt by the triangle fan edge, and guided smoothly through the 3D stripe curve on the fan surface, effectively enhancing the air flow. The semi-passive fans will remain off when the GPU is under a set loading or temperature for low power gaming. It allows gamers to enjoy gameplay in complete silence when the system is running light or idle.
  • WindForce 2x cooling system
  • Unique blade fan design
  • 3D active fan
  • One-click super overclocking
    With a simple click on XTREME engine utility, gamers can easily tune the card to meet their various gaming requirements without any overclocking knowledge, while saving the hassle of manual adjustment.
  • Ultra-cooling
    Lower RDS MOSFETs are specially designed to produce lower switching resistance for faster electric current charging and discharging at extremely low temperature.
  • Low power loss
    Metal choke hold energy much longer than common iron-core chokes at high frequency, thus effectively reduce core energy loss and EMI interference.
  • Longer life
    Lower ESR solid capacitors ensure better electronic conductivity for excellent system performance and longer lifespan.
  • Intuitive XTREME engine utility
    Clock speeds, voltage, fan performance, power target can be monitored and tuned in real-time according to your own preference through this intuitive interface.
Gigabyte GeForce GTX 1050 Ti OC 4G - graphics card - GF GTX 1050 Ti - 4 GB
Graphics card - low profile
Bus Type
PCI Express 3.0 x16
Graphics Engine
4 GB GDDR5
Core Clock
1328 MHz
Boost Clock
1442 MHz
Effective Memory Clock
7.008 GHz
Memory Interface
128-bit
Max Resolution
7680 x 4320
Max Resolution Details
DisplayPort: 7680 x 4320 at 60 Hz/ HDMI: 4096 x 2160 at 60 Hz
Max Monitors Supported
4
DVI-D (dual link) , DisplayPort , HDMI
API Supported
DirectX 12, OpenGL 4.5
3.7 cm x 16.7 cm x 6.89 cm
Bus Type
PCI Express 3.0 x16
Graphics Engine
Core Clock
1328 MHz
Boost Clock
1442 MHz
Process Technology
16 nm
Max Resolution
4
API Supported
Ultra Durable 2, solid state capacitors, NVIDIA G-Sync ready, NVIDIA GameWorks
Size
4 GB
GDDR5 SDRAM
Effective Clock Speed
7.008 GHz
Bus Width
128-bit
Required Power Supply
300 W
Software Included
GeForce Experience, XTREME Engine Utility
3.7 cm
16.7 cm
6.89 cm
Memory Size: 4GB
Memory Size: 4GB
Brand: Gigabyte
Price Range Ex VAT: 100 - 150
