Gigabyte GeForce RTX 4090 GAMING OC 24GB Graphics Card
Quicklinx: HVGQWS00 Mfr#: GV-N4090GAMING OC-24GD
The WINDFORCE cooling system features three 110mm unique blade fans, alternate spinning, 10 composite copper heat pipes, a large vapor chamber directly touches the GPU, 3D active fans and screen cooling, which together provide high efficiency heat dissipation.
Features:
  • NVIDIA Ada Lovelace Streaming Multiprocessors: Up to 2x performance and power efficiency
  • 4th Generation Tensor Cores: Up to 2X AI performance
  • 3rd Generation RT Cores: Up to 2X ray tracing performance
  • Powered by GeForce RTX® 4090
  • Integrated with 24GB GDDR6X 384-bit memory interface
  • WINDFORCE cooling system
  • RGB Fusion
  • Dual BIOS
  • Protection metal back plate
  • Anti-sag bracket
  • 4 Years Warranty (Online registration required)
    The WINDFORCE cooling system features three 110 mm designed bionic shark fans, alternate spinning, 10 composite copper heat pipes, a large vapor chamber directly touches the GPU, 3D active fans and Screen cooling, which together provide high efficiency heat dissipation.
  • 3D Active Fan
    The 3D Active Fan provides semi-passive cooling, and the fans will remain off when the GPU is in a low load or low power game.
  • Unique Blade Fan
    The airflow is split by the triangular fan edge, and guided smoothly through the 3D stripe curve on the fan surface.
  • Graphene nano lubricant
    Graphene nano lubricant can extend the life of sleeve bearing fan by 2.1 times, close to the life of double ball bearing, and is quieter
  • Screen cooling
    Extended heatsink allows air to pass through, providing better heat dissipation.
  • RGB Fusion
    The legendary three-ring lighting provides excellent visual enjoyment.
  • Ultra durable
    Ultra durable certified highest-grade metal chokes, lower ESR solid capacitors, 2 oz copper PCB, and lower RDS (on) MOSFETs, plus over-temperature design to deliver superior performance and longer system life.
  • Friendly PCB design
    Fully automated production process ensures top quality of the circuit boards and eliminates sharp protrusions of the solder connectors seen on the conventional PCB surface. This friendly design prevents your hands from getting cut or inadvertently damaging components when making your build.
Gigabyte GeForce RTX 4090 GAMING OC 24G - graphics card - NVIDIA GeForce RTX 4090 - 24 GB
Graphics card
Bus Type
PCI Express 4.0 x16
Graphics Engine
NVIDIA GeForce RTX 4090 - up to
24 GB GDDR6X
CUDA Cores
16348
Memory Interface
384-bit
Max Resolution
7680 x 4320
Max Monitors Supported
4
Interfaces Details
3 x DisplayPort , HDMI
API Supported
DirectX 12, OpenGL 4.6
15.02 cm x 34 cm x 7.52 cm
3-year warranty
Graphics card
Bus Type
PCI Express 4.0 x16
Graphics Engine
CUDA Cores
16348
Max Resolution
7680 x 4320
4
Interfaces Details
API Supported
Nvidia RT Core, NVIDIA Tensor Core, RGB fusion, Dual Bios, GIGABYTE WINDFORCE cooling design, metal backplate, 3D Active Fan
Size
24 GB
GDDR6X SDRAM
Bus Width
384-bit
Required Power Supply
1000 W
Additional Requirements
16 pin PCI Express power connector
DisplayPort 1.4
15.02 cm
34 cm
7.52 cm
Limited warranty - 3 years
