WINDFORCE cooling system
The WINDFORCE cooling system features three 110 mm unique blade fans, alternate spinning, 10 composite copper heat pipes, a large vapor chamber directly touches the GPU, 3D active fans and Screen cooling, which together provide high efficiency heat dissipation. -
RGB Fusion
With 16.7M customizable color options and numerous lighting effects, you can choose any lighting effect or synchronize with other devices in GIGABYTE CONTROL CENTER. -
Protection metal back plate
The metal back plate not only provides an aesthetical shape, but also enhances the structure of the graphics card to provide complete protection. -
Dual BIOS
The factory default setting is OC mode, which provides users with the best performance. However, switching to silent mode will enjoy a quieter experience. -
Power indicator
When experiencing any power supply abnormality, the indicator will alert gamers by flashing light. -
Anti-sag bracket
The anti-sag bracket is tailored to each graphics card. It provides the optimized reinforcement and better overall visual appearance. -
Ultra durable
Ultra durable certified highest-grade metal chokes, lower ESR solid capacitors, copper PCB, and lower RDS(on) MOSFETs, plus over-temperature design to deliver superior performance and longer system life. -
Friendly PCB design
Fully automated production process ensures top quality of the circuit boards and eliminates sharp protrusions of the solder connectors seen on the conventional PCB surface. This friendly design prevents your hands from getting cut or inadvertently damaging components when making your build.
- Gigabyte GeForce RTX 4090 AERO OC 24G - graphics card - NVIDIA GeForce RTX 4090 - 24 GB
- Graphics card
- Bus Type
- PCI Express 4.0
- Graphics Engine
- NVIDIA GeForce RTX 4090 - up to
- Memory
- 24 GB GDDR6X
- Memory Speed
- 21 Gbps
- Boost Clock
- 2535 MHz
- CUDA Cores
- 16384
- Memory Interface
- 384-bit
- Max Resolution
- 7680 x 4320
- Max Monitors Supported
- 4
- Interfaces Details
- HDMI , 3 x DisplayPort
- API Supported
- OpenGL 4.6, DirectX 12 Ultimate
- 7.5 cm x 34.2 cm x 15 cm
- 4-year warranty with product registration
- Graphics card
- Bus Type
- PCI Express 4.0
- Graphics Engine
- Boost Clock
- 2535 MHz
- CUDA Cores
- 16384
- Max Resolution
- 7680 x 4320
- 4
- API Supported
- NVIDIA Ada Lovelace GPU technology, 4th gen Tensor Cores, 3rd gen Ray Tracing Cores, NVIDIA DLSS 3, GIGABYTE WINDFORCE cooling design, RGB fusion, Dual Bios, metal backplate, Gigabyte Alternate Spinning, 110mm unique blade fan design, 3D Active Fan, screen cooling, Graphene Nano Lubricant, Vapor chamber cooling technology, HDCP
- Size
- 24 GB
- Technology
- GDDR6X SDRAM
- Memory Speed
- 21 Gbps
- Bus Width
- 384-bit
- Required Power Supply
- 1000 W
- Additional Requirements
- 16 pin PCI Express power connector
- Included Accessories
- Anti-sag bracket, 16-pin to 4x 8-pin cable adapter
- Software Included
- Gigabyte Control Center
- DisplayPort 1.4, HDCP 2.3
- 7.5 cm
- 34.2 cm
- 15 cm
- Limited warranty - 4 years with product registration
