The GTX 950 Xtreme Gaming graphics card is the first of many gamer-focused products that GIGABYTE will be rolling out this year. This graphics card is built upon the Super Overclock GPU along with the well-acclaimed WINDFORCE cooling solution featuring 3D-Active Fan to deliver the finest gaming experience and silent cooling performance in the same category.
Xtreme performance
The GTX 950 Xtreme Gaming is forged with the top-notch GPU core through the very own GPU Gauntlet Sorting technology that guarantees exceptional overclocking with stability. The memory is also overclocked to 7Gbps for the sharpest and smoothest gameplay results. Gamers could expect up to more than 2X improvement with the GTX 950 Xtreme Gaming at 4K ultra settings on popular MOBA games compared to GTX 750Ti, making it the graphics card to own for performance-demanding gamers. -
Xtreme cooling
The GTX 950 Xtreme Gaming features the WINDFORCE 2X cooling system with pure copper heat pipes which directly touch the GPU to improve the speed of heat dissipation. The air flow is effectively enhanced by the unique blade fan design to increase the cooling capacity while reducing air turbulence at a very low noise level. -
Xtreme protection
The PCB of the GTX 950 Xtreme Gaming is applied with a breathable coating to shield against moisture, dust, and corrosion for a complete protection. This aerospace-grade coating is ideal for gamers who live in regions with high humidity or extreme temperatures. Even gamers who practice LN2 overclocking or water-cooling could also benefit from this feature to prevent damages from coolants or possible leaks. -
Xtreme outlook
In addition to the stylish back plate, the new stealth aesthetics and multi-color illumination of the GTX 950 Xtreme GAMING corresponds to the excitement of X Xtreme Gaming with a premium gaming look. The WINDFORCE LED emblem let gamers personalize their own builds that best suit their gaming ambience with 7 dazzling colors. With extra color options and complementary lighting effects, gamers can easily customize the right scheme for their gaming rigs through GIGABYTE OC GURU II utility software. -
Xtreme durability
The GTX 950 Xtreme Gaming is reinforced with top quality components to bring gamers with the ultimate durability ever. Engineered with the same highest-grade chokes and capacitors as those of Titan X, the graphics card delivers the ultimate integration of thermal, electric characteristics, digital signals, power circuitry for enhanced results and longer system lifespan.
- Gigabyte GV-N950XTREME-2GD - graphics card - GF GTX 950 - 2 GB
- Graphics card
- Bus Type
- PCI Express 3.0 x16
- Graphics Engine
- NVIDIA GeForce GTX 950
- Memory
- 2 GB GDDR5
- Core Clock
- 1203 MHz
- Boost Clock
- 1405 MHz
- Effective Memory Clock
- 7 GHz
- Memory Interface
- 128-bit
- Max Resolution
- 4096 x 2160
- Max Monitors Supported
- 4
- Interfaces Details
- DVI-I (dual link) , 3 x DisplayPort , HDMI
- API Supported
- DirectX 12, OpenGL 4.5
- 4.2 cm x 24 cm x 13.2 cm
- Graphics card
- Bus Type
- Graphics Engine
- Core Clock
- 1203 MHz
- Boost Clock
- 1405 MHz
- Process Technology
- 28 nm
- Max Resolution
- 4096 x 2160
- 4
- API Supported
- Ultra Durable VGA, LED indicator, Extreme Cooler, GIGABYTE GPU Gauntlet Sorting, MSI Solid Capacitor, Nvidia 3D Vision technology, GIGABYTE WindForce 2x, Dual Fan Design, OC Guru II
- Size
- 2 GB
- Technology
- GDDR5 SDRAM
- Effective Clock Speed
- 7 GHz
- Bus Width
- 128-bit
- Required Power Supply
- 350 W
- Additional Requirements
- 8 pin PCI Express power connector
- Software Included
- OC Guru ll
- 4.2 cm
- 24 cm
- 13.2 cm
