As opposed to the stereotype, GIGABYTE is able to maximize fan size to 10cm with the latest cooling design. With a 10cm fan, the card is virtually silent that its noise level runs much lower. The airflow is split through the triangle design at the fan edge, and is guided smoothly through the fan by special 3D stripe curve design. At the same time, it effectively enhanced the cooling capacity while reducing air turbulence.
Unique blade fan design
The airflow is split through the triangle design at the fan edge, and is guided smoothly through the fan by special 3D stripe curve design. At the same time, it effectively enhanced the cooling capacity while reducing air turbulence. -
Up to 4 displays on a single card
Support up to four displays on a single card. Satisfy your multi-screen setup, high definition and extreme gaming experience. -
Gold plated HDMI x 2
Gold plated, durable large contact area connectors have been used for optimum signal transfer between connections. Dual HDMI design lets users experience broader, richer gaming environments with better resolution on a single card. -
Ultra cooling
Lower RDS(on) MOSFETs are specially designed to produce lower switching resistance for faster electric current charging and discharging at extremely low temperature. -
Low power loss
Ferrite core chokes hold energy much longer than common iron-core chokes at high frequency, thus effectively reduce core energy loss and EMI interference. -
Longer life
Lower ESR solid capacitors ensure better electronic conductivity for excellent system performance and longer lifespan. -
OC GURU 2
Brand-new intuitive user interface helps you easily modify important settings and directly update driver and BIOS. Clock speeds, voltage, fan performance, and OSD setting can be monitored and tuned in real-time according to your own preference.
- Gigabyte GV-N75TOC-1GI (rev. 1.0) - OC Edition - graphics card - GF GTX 750 Ti - 1 GB
- Graphics card
- Bus Type
- PCI Express 3.0 x16
- Graphics Engine
- NVIDIA GeForce GTX 750 Ti
- Memory
- 1 GB GDDR5
- Core Clock
- 1033 MHz
- Boost Clock
- 1111 MHz
- Effective Memory Clock
- 5.4 GHz
- Memory Interface
- 128-bit
- Max Resolution
- 4096 x 2160
- Max Monitors Supported
- 4
- Interfaces Details
- DVI-I (dual link) , DVI-D (dual link) , 2 x HDMI
- API Supported
- OpenGL 4.4, DirectX 12
- 4.3 cm x 18.5 cm x 13.5 cm
- Graphics card
- Bus Type
- Graphics Engine
- Core Clock
- 1033 MHz
- Boost Clock
- 1111 MHz
- Process Technology
- 28 nm
- Max Resolution
- 4096 x 2160
- 4
- API Supported
- Ultra Durable 2, Gold plated HDMI, OC Guru II
- Size
- 1 GB
- Technology
- GDDR5 SDRAM
- Effective Clock Speed
- 5.4 GHz
- Bus Width
- 128-bit
- Required Power Supply
- 400 W
- Additional Requirements
- 6 pin PCI Express power connector
- Software Included
- OC Guru ll
- 4.3 cm
- 18.5 cm
- 13.5 cm
