GeForce GTX 1080 Xtreme Gaming Premium Pack
Powered by GeForce® GTX 1080
WINDFORCE Stack 3x 100mm fan cooling system
Xtreme VR Link provides the best VR experience
16.8M customizable color lighting
Xtreme SLI bridge with light effect
Stylish Metal Back Plate
Titan X-grade Chokes and Capacitors for Extreme Durability
Intuitive Xtreme Engine
Xtreme Care provides 4 years warranty (Online registration required)
Core
Boost: 1936 MHz / Base: 1784 MHz in OC mode
Boost: 1898 MHz / Base: 1759 MHz in Gaming mode
XTREME PERFORMANCE
GIGABYTE Xtreme Gaming Series graphics cards are crafted for perfection in pursuit of the ultimate graphics experience for gaming enthusiasts. Based on the revolutionary NVIDIA® Pascal™ GPU architecture, Xtreme gaming graphics card brings you incredible gaming experience.
- Pascal-powered graphics card give you superior performance and power efficiency
- Support up to 8K display @60Hz (requires 2*DP1.3 connectors)
- Outstanding performance for Virtual Reality gaming
Advanced cooling system
The cooling system features a special fan design, double ball bearing structure, angular fin design and composite heat pipes, together delivering an effective heat dissipation capacity for higher performance at lower temperatures. -
Stack fan design
The stack fans provide larger and smoother airflow. And with more heatsink coverage, these stack fans will have better cooling performance. -
Special fan design
The airflow is split by the triangle fan edge, and guided smoothly through the 3D stripe curve on the fan surface, effectively enhancing the airflow. -
Double ball bearing structure
The double ball bearing structure has better heat endurance and efficiency than sleeve structure. Hence it will provide longer life time. -
Composite heat pipes
The composite heat pipes combine both thermal conductivity and phase transition for efficiently managing the transfer of heat between two solid interfaces which increases the cooling capacity. -
Large copper base plate
With direct contact to the GPU and VRAM, the large copper base plate combines the composite heat pipes to efficiently transfer heat generated from the interior cores to the heat sink, keeping the graphics card cool and stable for better performance.
- Gigabyte GeForce GTX 1080 Xtreme Gaming - graphics card - GF GTX 1080 - 8 GB
- Graphics card
- Bus Type
- PCI Express 3.0 x16
- Graphics Engine
- NVIDIA GeForce GTX 1080
- Memory
- 8 GB GDDR5X
- Core Clock
- 1784 MHz
- Boost Clock
- 1936 MHz
- Effective Memory Clock
- 10.4 GHz
- Memory Interface
- 256-bit
- Max Resolution
- 7680 x 4320
- Max Monitors Supported
- 4
- Interfaces Details
- DVI-D (dual link) , 3 x DisplayPort , HDMI
- API Supported
- DirectX 12, OpenGL 4.5
- 5.6 cm x 28.9 cm x 13.8 cm
- 4 years warranty
- Graphics card
- Bus Type
- Graphics Engine
- Core Clock
- 1784 MHz
- Boost Clock
- 1936 MHz
- Process Technology
- 16 nm
- VR Ready
- Max Resolution
- 7680 x 4320 at 60 Hz
- 4
- API Supported
- Ultra Durable VGA, LED indicator, GIGABYTE WindForce 3x, Dual ball Bearing Fan, NVIDIA G-Sync ready, NVIDIA GameWorks, 12+2 Phase Power Design, Nvidia GeForce GTX VR Ready
- Size
- 8 GB
- Technology
- GDDR5X SDRAM
- Effective Clock Speed
- 10.4 GHz
- Bus Width
- 256-bit
- Required Power Supply
- 500 W
- Additional Requirements
- 2 x 8 pin PCI Express power connector
- Included Accessories
- Backplate
- Software Included
- XTREME Engine Utility
- 5.6 cm
- 28.9 cm
- 13.8 cm
- Limited warranty - 4 Years
