Product
Gigabyte GeForce GTX 1080 XTREME 8GB GDDR5X Waterforce
Quicklinx: C5QLWS00 Mfr#: GV-N1080XTREME W-8GD
GIGABYTE Xtreme Gaming Series graphics cards are crafted for perfection in pursuit of the ultimate graphics experience for gaming enthusiasts. Based on the revolutionary NVIDIA® Pascal™ GPU architecture, Xtreme gaming graphics card brings you incredible gaming experience.
  • Pascal-powered graphics card give you superior performance and power efficiency
  • Support up to 8K display @60Hz (requires 2*DP1.3 connectors)
  • Outstanding performance for Virtual Reality gaming
  • The ultimate PC gaming platform
    Get Game Ready with GeForce GTX. GeForce GTX delivers extremely fast performance, with the advanced gaming technologies (NVIDIA GameWorks) and an amazing gaming ecosystem (GeForce Experience).
  • Cinematic game experience
    GameWorks pushes the limits of gaming by providing a more interactive and cinematic game experience and thus enabling next gen gaming for current games.
  • Tear-free gameplay
    G-SYNC's revolutionary smoothness is achieved by synchronizing display refresh rates to the GPU in your GeForce GTX-powered desktop or notebook, eliminating screen tearing and minimizing display stutter and input lag.
  • 100% water cooling
    Without any extra fan on the card, WATERFORCE provides the best cooling solution for the GPU/RAM/MOSFET. The copper base and copper heat-pipe dissipate the heat efficiently to result in a real silent environment.
  • WATERFORCE with all-in-one cooling system
    The WATERFORCE all-in-one cooling system is a pre-assembled and pre-filled liquid solution that provides the easiest way for installation. The optimized pump and water block deliver the most efficient water flow and cooling performance at a lower noise level.
  • 120mm unique blade fan design
    The 120mm dynamic adjusting fan provides the silent operation. The airflow is split by the triangle fan edge, and guided smoothly through the 3D stripe curve on the fan surface, effectively enhancing the airflow by 23% over the traditional fans.
  • Double ball bearing structure
    The double ball bearing structure has better heat endurance and efficiency than sleeve structure. Hence it will provide longer life time.
  • Aluminum radiator
    Built in 120mm black aluminum radiator help to dissipate the heat efficiently.
  • Braided FEP tubes
    With nearly no moisture absorption, high thermal stability and high pressure tolerance, the sturdy FEP tubes greatly enhance product life and durability.
  • Xtreme VR Link
    Xtreme VR Link provides the best solution for both VR device demand with 3 HDMI ports and 3x 4k monitors demand with 3 DP ports. Outputs are automatically detected when restarting PC.
  • 16.8M customizable color lighting
    With 16.8M customizable color options and numerous lighting effects, you could now choose the right scheme for your gaming rig through XTREME Engine utility.
Gigabyte GeForce GTX 1080 Xtreme Gaming Water cooling - graphics card - GF GTX 1080 - 8 GB
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
NVIDIA GeForce GTX 1080
8 GB GDDR5X
Core Clock
1784 MHz
Boost Clock
1936 MHz
Effective Memory Clock
10.416 GHz
Memory Interface
256-bit
Max Resolution
7680 x 4320
Max Monitors Supported
4
DVI-D (dual link) , 3 x DisplayPort , HDMI
API Supported
DirectX 12, OpenGL 4.5
4.1 cm x 26.4 cm x 12.4 cm
4 years warranty
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
Core Clock
1784 MHz
Boost Clock
1936 MHz
Process Technology
16 nm
VR Ready
Max Resolution
7680 x 4320
4
API Supported
LED indicator, Triangle Cool Technology, NVIDIA G-Sync ready, NVIDIA GameWorks, WATERFORCE: All In One Water Cooling System, Nvidia GeForce GTX VR Ready
Size
8 GB
GDDR5X SDRAM
Effective Clock Speed
10.416 GHz
Bus Width
256-bit
Required Power Supply
500 W
Additional Requirements
8 pin PCI Express power connector
4.1 cm
26.4 cm
12.4 cm
Limited warranty - 4 Years
