Your basket is empty
Gigabyte GeForce GTX 1080 XTREME 8GB GDDR5X Waterforce
Quicklinx: C5QLWS00 Mfr#: GV-N1080XTREME W-8GD
GIGABYTE Xtreme Gaming Series graphics cards are crafted for perfection in pursuit of the ultimate graphics experience for gaming enthusiasts. Based on the revolutionary NVIDIA® Pascal™ GPU architecture, Xtreme gaming graphics card brings you incredible gaming experience.
  • Pascal-powered graphics card give you superior performance and power efficiency
  • Support up to 8K display @60Hz (requires 2*DP1.3 connectors)
  • Outstanding performance for Virtual Reality gaming
Gigabyte GeForce GTX 1080 Xtreme Gaming Water cooling - graphics card - GF GTX 1080 - 8 GB
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
NVIDIA GeForce GTX 1080
8 GB GDDR5X
Core Clock
1784 MHz
Boost Clock
1936 MHz
Effective Memory Clock
10.416 GHz
Memory Interface
256-bit
Max Resolution
7680 x 4320
Max Monitors Supported
4
DVI-D (dual link) , 3 x DisplayPort , HDMI
API Supported
DirectX 12, OpenGL 4.5
4.1 cm x 26.4 cm x 12.4 cm
4 years warranty
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
Core Clock
1784 MHz
Boost Clock
1936 MHz
Process Technology
16 nm
Max Resolution
7680 x 4320
4
API Supported
LED indicator, Triangle Cool Technology, NVIDIA G-Sync ready, NVIDIA GameWorks, WATERFORCE: All In One Water Cooling System, Nvidia GeForce GTX VR Ready
Size
8 GB
GDDR5X SDRAM
Effective Clock Speed
10.416 GHz
Bus Width
256-bit
Required Power Supply
500 W
Additional Requirements
8 pin PCI Express power connector
4.1 cm
26.4 cm
12.4 cm
Limited warranty - 4 Years
