Gigabyte GeForce GTX 1080 G1 GAMING 8GB GDDR5X Windforce3X Graphics
Quicklinx: C5MZWS00 Mfr#: GV-N1080G1 GAMING-8GD
Get Game Ready with GeForce GTX. GeForce GTX delivers the fastest performance, with the advanced gaming technologies (NVIDIA GameWorks) and the best gaming ecosystem (GeForce Experience). G-SYNC's revolutionary smoothness is achieved by synchronizing display refresh rates to the GPU in your GeForce GTX-powered desktop or notebook, eliminating screen tearing and minimizing display stutter and input lag.
  • The ultimate PC gaming platform
  • Cinematic game experience
    GameWorks pushes the limits of gaming by providing a more interactive and cinematic game experience and thus enabling next gen gaming for current games.
  • Tear-free gameplay
  • Amazing virtual reality experience
    Get you ready for the fast performance and low latency required for an amazing virtual reality experience.
  • Unique blade fan design
    The airflow is spilled by the triangle fan edge, and guided smoothly through the 3D stripe curve on the fan surface, effectively enhancing the air flow over traditional fans.
  • 3D active fan with LED indicators
    The semi-passive fans will remain off when the GPU is under a set loading or temperature for low power gaming. The LED fan indicator on the top of the graphics card provides an instant display of the fan status.
  • Composite heat-pipes
    The composite heat-pipes combines both thermal conductivity and phase transition for efficiently managing the transfer of heat between two solid interfaces which increases cooling capacity.
  • Heat pipe direct touch
    The pure copper heat pipes are shaped to maximize the direct contact area to the GPU.
  • Triangle Cool technology
    By the combination of fins and aluminum clip module, GIGABYTE patented "Triangle Cool" Technology enhances the efficiency of heat dissipation dramatically.
  • 16.8M customizable color lighting
    With 16.8M customizable color options and numerous lighting effects, you could now choose the right scheme for your gaming rig through XTREME Engine utility.
  • One-click Super overclocking
    With a simple click on XTREME Engine utility, gamers can easily tune the card to meet their various gaming requirements without any overclocking knowledge, while saving the hassle of manual adjustment.
  • GPU gauntlet sorting
    Forged with only the top-notch GPU, the Gigabyte G1 GAMING graphics cards guarantee higher overclocking capability in terms of excellent power switching, ensuring the highest performance without compromising system reliability.
  • Smart power LED indicators
    Be alert when PCI-E voltage is unstable with the smart power LED indicator.
  • Ultra durable materials
    Engineered with the highest-grade chokes and capacitors, this graphic card delivers outstanding performance and durable system lifespan.
Gigabyte GeForce GTX 1080 G1 Gaming - OC Edition - graphics card - GF GTX 1080 - 8 GB
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
NVIDIA GeForce GTX 1080
8 GB GDDR5X
Core Clock
1721 MHz
Boost Clock
1860 MHz
Effective Memory Clock
10.01 GHz
Memory Interface
256-bit
Max Resolution
7680 x 4320
Max Monitors Supported
4
Interfaces Details
DVI-D (dual link) , 3 x DisplayPort , HDMI
API Supported
DirectX 12, OpenGL 4.5
4.2 cm x 28.6 cm x 11.5 cm
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
Core Clock
1721 MHz
Boost Clock
1860 MHz
Process Technology
16 nm
VR Ready
Max Resolution
7680 x 4320
4
Interfaces Details
API Supported
Ultra Durable VGA, LED indicator, GIGABYTE GPU Gauntlet Sorting, GIGABYTE WindForce 3x, Triangle Cool Technology, NVIDIA G-Sync ready, NVIDIA GameWorks, Heat Pipe Direct Touch technology, Nvidia GeForce GTX VR Ready
Size
8 GB
GDDR5X SDRAM
Effective Clock Speed
10.01 GHz
Bus Width
256-bit
Required Power Supply
500 W
Additional Requirements
8 pin PCI Express power connector
4.2 cm
28.6 cm
11.5 cm
